Door Handle LED (Blue)
Old Aug 31, 2009 | 07:47 PM
lbz's Avatar
lbz
Default Door Handle LED (Blue)
Inspired by audiom3's post titled "Goin Green" https://my350z.com/forum/exterior-an...ing-green.html, I decided to expand my conversion project to the door handles.
I did the driver's side yesterday. I was concerned that the 3mm LED I planned to use would not be enough but it actually came out pretty much like I wanted. Just a hint of blue around the trailing edge when seen directly from the side.
This pic taken at dusk without flash.
I tapped in at the dome light assembly, figured that would make it simple and not that much more work.
Old Aug 31, 2009 | 08:05 PM
King350Z's Avatar
King350Z
pretty sick looking
Old Aug 31, 2009 | 08:30 PM
AlvinHuyN's Avatar
AlvinHuyN
Nismo 370Z #697
looks nice but when is it on? Not all the time I hope...
Old Aug 31, 2009 | 08:37 PM
lbz's Avatar
lbz
LOL! Not on all the time. Comes on when the dome light comes on and turns off when the dome light turns off, including when unlocking and locking with the remote.
Old Aug 31, 2009 | 08:56 PM
calin's Avatar
calin
Wow, very nice!! Nice and clean
Old Aug 31, 2009 | 09:22 PM
diablox1's Avatar
diablox1
how about you post some night time pics?
Old Aug 31, 2009 | 09:28 PM
lbz's Avatar
lbz
Tough to do without a flash and my dinky little Canon SureShot but I'll break out the tripod and try it.
Old Aug 31, 2009 | 09:30 PM
2k6-z33's Avatar
2k6-z33
Looks good... Interesting I'd like to see this done in red.
Old Aug 31, 2009 | 09:46 PM
Waiz's Avatar
Waiz
In the same red as the dash, yesiiirrrrrr
Old Aug 31, 2009 | 09:50 PM
2k6-z33's Avatar
2k6-z33
^Nope apple red
Old Aug 31, 2009 | 10:22 PM
AlvinHuyN's Avatar
AlvinHuyN
Nismo 370Z #697
That's sick then So it'll stay lit after unlocking until you turn the key right? noiiiiice!
Old Aug 31, 2009 | 10:49 PM
audiom3's Avatar
audiom3
Looking good!!! I just finished my passenger side door tonight because I had issues with it the first time. When you go anywhere at night and unlock your doors it looks absolutely amazing
Old Aug 31, 2009 | 10:54 PM
lbz's Avatar
lbz
Correct sir! The leads for the LED come right off the contacts for the dome light bulbs so they are controlled by whatever controls the dome lights including the manual switches.
The LED sticks into the inside of the handle a little bit. I was trying to go for a flush mount with the top of the bulb barely sticking up past the surface but the handle rotates on the axis of the hinge causing it to move in an arc. This causes it to make contact with the bulb if its mounted on the stationary part. I figure if left that way, after a while it's going to scuff the bulb up pretty good or damage it.
I decided to mount it so the LED travels with the handle piece that moves. A little shrink wrap around the leads and a fine round file around the drill hole prevents the leads from chaffing each time the handle is pulled.
So far, my fingers have brushed it once or twice so I figure when I do the passenger side, I will try to move it deeper into the handle, hopefully will not affect the brightness, maybe try using a 5mm LED, like Audiom3 did, instead.
Will experiment and post the results this weekend.
Old Sep 2, 2009 | 04:39 AM
MDaniel22's Avatar
MDaniel22
In for more pics. Nice job.
Old Sep 2, 2009 | 05:38 AM
ChaserAero's Avatar
ChaserAero
Vendor - Former Vendor
Looks clean! Definitely in for some night shots!
Old Sep 2, 2009 | 05:55 AM
Asian Invasian's Avatar
Asian Invasian
nice!
Old Sep 2, 2009 | 09:48 PM
lbz's Avatar
lbz
As promised -night shots
This was under the lights in the parking area behind my place.
Slightly off center biased from the rear, low light in the alley
Pretty much same angle, closer up
Blue tint on the steering wheel is coming from blue LED dome lights. I haven't decided if I will keep those or replace with white.
From straight across
Old Sep 3, 2009 | 05:11 AM
ChaserAero's Avatar
ChaserAero
Looks great!!! My friend's BMW has these and I have always liked the look.... well done!
Old Sep 3, 2009 | 06:20 PM
scmtkings4's Avatar
scmtkings4
looks cool man
perhaps just a plain white?
Old Sep 3, 2009 | 07:19 PM
lbz's Avatar
lbz
Originally Posted by scmtkings4
looks cool man
yeah, I thought about that actually, would go better with the Silverstone, BUT it would not match with this:
