Aluminum pedals installation tip!
Old Oct 8, 2003 | 03:49 AM
yoyo's Avatar
yoyo
Smile Aluminum pedals installation tip!
I just installed my new aluminum kickplates and aluminum pedal set.
I read previous threads on the installation and the typical 20 min. to install the brake and clutch covers.
Well, I soaked my covers in hot water for 5 min. ( I´m not sure they soften that much but one looses nothing in doing it)
For the installation of the clutch and brake pads I helped the installation by using a small flat head screw driver with wich I pulled the corners of the pads ( back) against the corners of the pedal . I did both in 7 or 8 mins. the whole set in less than 15 to 20 min.
If you use the small srew driver to help the installation its not too diff. at all.
I hope this tip helps others in their inslallation.
Those pedals do look great!!!!!
Yoyo
Old Oct 8, 2003 | 07:16 AM
yobri's Avatar
yobri
Thanks Yo. Will remember the tip.
Old Oct 8, 2003 | 10:11 AM
Vash's Avatar
Vash
Yoyo great tips, I wish I’d read this post before I installed mine. It took me an hour before I figure it out let a hair dryer heat it up for 30sec will make the work a lot easier.
sales@czp
Sep 23, 2019 03:30 PM
nanotech
Oct 2, 2015 05:02 AM
