New project I have been working on, Aluminum belly pans
www.RareJdm.com already has these for sale
OMG YOU MEAN SOMEONE MAKES A UNDERTRAY REPLACEMENT?
WHO HAS EVER HEARD OF THIS PRODUCT EXISTING IN THE MARKET BEFORE THE OP? YOU ARE ****ING AMAZING AND TOTALLY JDM AWESOME AND KNOW ALL THE SECRETS. TELL ME MORE SECRETS! DOES ANYONE MAKE WHEELS DIFFERENT FROM THE OEMS THAT I CAN INSTALL? WHAT A BOUT AIR FILTERS?
tool.
Hey guys, This is the last prototype (hopefully), I will test fit tomorrow and get some more pics up then its off to be test run on a car for a week or so! After that they will go into production. Few notes, From working with this in aluminum it is going to pick up a few minor scuffs/scratches in production, We are going to protect the showing, bottom side as best we can and try to keep them as clean as possible but they are not going to come out completely perfect. These are going to be in the $250 range, From the looks of it there are is a lot of interest and the more I run at a time the better pricing I will get.
After the last test fit and field tests I will be posting up in the sponsor area and possibly do a pre-order with a pre-order price
This will give me a better idea of how many I need to run on the first batch.
If this sounds good to all of you please let me know what you think. If you have any suggestions now is the time!
The vents are gone, Vents plenty well without them and saves almost .5" in ground clearance ( I know this is an issue so I have designed this to give as much ground clearance as possible.
It is pretty much level with the front fascia all the way back to the oil filter access door.
I have also moved the rear bend forward to accommodate the GTSpec front tie bar. There is plenty of room to get to the oil filter with or without the tiebar installed.
These will be made of 5052 .050" aluminum stock. This material is very rigid and durable, sure to last a very long time.
I made the 2 bigger pieces separate so they can be shipped by normal shipping means. Otherwise they would be oversize and be almost $100 to ship adding to your cost.
I am interested! Mine has taken two beatings and would like a new one. My questions is since your making a two pieces design do you think you would ever make the front piece for a Nismo v3 bumper? I am pretty sure the back could stay the same cutting design time and cost down and getting a larger customer base! I am looking at installing OEM v3 and id rather spend money on this then 400$ on OEM one for Nismo under plastic!
Is the V3 the 08 nismo front fascia? Sorry for my ignorance with this but if it is the Nismo front fascia that comes stock on the 08 Nismo Z I can probably get my hands on it to make it.
What's Up! Looking forward to the test fit this Thursday. Trust me, I will field test the &*%@ out of it on my drive to St. Louis this weekend.
You never know who you are gonna run into in a RiteAid parking lot.
Your TT 300 sounded sick driving off.
http://www.thenismoshop.com/ikorb.ph...oduct_id=12959
