Healdlight OUt?
Old Sep 21, 2009 | 04:17 AM
RussucoBlack350's Avatar
RussucoBlack350
Default Healdlight OUt?
Hey guys need some help here, my drivers side headlight went out this morning. Now its not the turn signal and its not the the lower bulb its the circular light in the middle. I believe it might be the L.e.d now i was wondering how i would go about fixing this, if its just a bulb or am i going to be paying alot to fix it. Thanks for your help guys
Russuco
Old Sep 21, 2009 | 04:20 AM
350blue's Avatar
350blue
what model and year your have
Old Sep 21, 2009 | 04:45 AM
RussucoBlack350
I have a 2003 Performance model.
Old Sep 21, 2009 | 05:18 AM
duro78's Avatar
duro78
HUH ? its a burnt out bulb just like in your home it burns out and you change it. Take bumper off remove light 3 bolts if i remember correctly find bad bulb and change it reverse process. there is no l.e.d. Doesnt seem like your too mechanical so you should find someone to do it you might find taking the bumper off a little difficult but its not.
Old Sep 21, 2009 | 05:36 AM
RussucoBlack350
ok then i am actually some what mechanical i just had someone tell me it was a H.I.D, would you happen to know what bulb or the bulb number would be i dont have the owners manual.
Russ
Old Sep 21, 2009 | 06:03 AM
KornerCarver's Avatar
KornerCarver
Here you go.............................
http://www.tirerack.com/lighting/det...3&autoModClar=
Old Sep 21, 2009 | 10:58 AM
RussucoBlack350
do i need to purchse that light it seems to be a upgrade to my stock ones...is there anyway to replace the stock H.I.D do i need a new balast of do i need a new HID headlight and how would I Install this.
Russuco
Old Sep 21, 2009 | 12:07 PM
TheFarmer's Avatar
TheFarmer
Use the search function on this site to get your answers, there's a lot of threads on how to remove the bulbs yourself.
As for the ballast how do you know it's bad? Get it tested by a mechanic if you're worried about it.
