Looking for a body kit, which one?
Old Sep 22, 2009 | 07:46 AM
LSX-PWR's Avatar
LSX-PWR
Question Looking for a body kit, which one?
I am looking for a body kit right asap because this yahoo in a bigo truck backed up in to my car. It jacked up the passenger fender, front bumper cover and even broke the head light. I am going to replace all these parts and I figured i might as well get a body kit while I am at it. The only thing is which one would look good. I was thinking of one of these? I'm opened for ideas.
1.)B2 Wide body kit
2.)Extreme Dimensions C-2 body kit
3.)Vader 3 Wide body kit
4.)Chargespeed
Old Sep 22, 2009 | 08:21 AM
MethodRN's Avatar
MethodRN
For Sale
Chargespeed, not sure why those other ones are being considered.
Old Sep 22, 2009 | 08:24 AM
ChanceWarren's Avatar
ChanceWarren
For real. Go with Chargespeed.
Old Sep 22, 2009 | 08:54 AM
LSX-PWR's Avatar
LSX-PWR
The only reason I was thinking of the wide body kits is because I wanted to fit a wide tire in the rear. Is the Chargespeed made of good material like the one's from Duraflex? Whats the whole kit sell for and from whom should I purchase it from?
Old Sep 22, 2009 | 09:02 AM
zerafian's Avatar
zerafian
you can go 305 tires with the stock body. I think its more about offset of rims then tire size when it comes to widebody kits. You really wanna spend over $1600 on tires?. I would stick with chargespeed from those choices.
Old Sep 22, 2009 | 09:14 AM
LSX-PWR's Avatar
LSX-PWR
The reason I want a wide tire in the rear cause I am going to put LS7 441 which is going to be pumping out little over 700hp at the rear wheels. Plus a direct port 250 shot of nitrous. So the more rubber I have in the rear the better. i know there is more to it, but its a start.
Old Sep 22, 2009 | 09:45 AM
ChanceWarren
Well... obviously, money is no object. Chargespeed has a super wide body kit as well. It's not very pretty, but... sounds like you want a drag racer. It would fit the bill. I'm not certain but I think you can get Chargespeed kits at Vividracing.
Old Sep 22, 2009 | 10:13 AM
AreYouAMac's Avatar
AreYouAMac
LS7? That's crazy. When will your project be complete? And what size tires will you be running for the rear? 305 or 315?
Old Sep 22, 2009 | 10:52 AM
zerafian's Avatar
zerafian
go with Do Luck wide body kit
Old Sep 22, 2009 | 11:29 AM
LSX-PWR's Avatar
LSX-PWR
I am working on it as we speak. Here's what the engine built off:
-Becks sheetmetal intake
-Extreme 115mm tb
-TNT direct port injection 250-300 jets
-C5R heads CNC ported by West Coast Cylinder Heads "WCCH" They flow little over 400cfm at 700 lift through 2.20 ti valve and 1.62 stainless valve which flow 280cfm
-Jessel shaft mounted Rocker arms 1.85
-Morels lifters
-comp moley push rods
-sheetmetal valve covers
-LS7 block
-Callies 4.125 crank
-Compstar HD- I Beam rated at 1500+ HP
-JE 4.125 custom pistons, coated
-Rings total seal
-Arp everything bolts
Old Sep 22, 2009 | 11:39 AM
LSX-PWR's Avatar
LSX-PWR
Nice kit, I am sure that bad boy takes a lot of work to put on.
Old Sep 22, 2009 | 07:58 PM
zerafian's Avatar
zerafian
If you have the time and money to order it, wait for it to be made, and to have it shipped its well worth it believe me.
Old Sep 22, 2009 | 08:19 PM
2k6-z33's Avatar
2k6-z33
Chargespeed.
Old Sep 22, 2009 | 11:03 PM
ITOzann's Avatar
ITOzann
^+1
Old Sep 23, 2009 | 10:36 AM
ImWeeZzel's Avatar
ImWeeZzel
pictures would help this thread...
Old Sep 23, 2009 | 03:44 PM
Chebosto's Avatar
Chebosto
1.)B2 Wide body kit --> same as.. Veilside v3
2.)Extreme Dimensions C-2 body kit --> same as... Cwest short nose
3.)Vader 3 Wide body kit --> same as... Veilside v3
4.)Chargespeed --> same as... Chargespeed!
i'd do #4.
Old Sep 23, 2009 | 04:29 PM
TheFarmer's Avatar
TheFarmer
Out of the ones you have listed, Chargespeed.
Old Sep 23, 2009 | 06:26 PM
sublimemoment's Avatar
sublimemoment
Please tell me you are going to start a build thread for this.
Old Sep 23, 2009 | 06:35 PM
Hexxus's Avatar
Hexxus
Old Sep 23, 2009 | 09:43 PM
ChanceWarren
B2 isn't the same as Veilside 3. I don't know that I'd go so far as to say the differences are subtle but regardless, the two kits are definitely not the same.
