Post your keys :D
Old Oct 20, 2009 | 01:56 PM
  #41
ChanceWarren's Avatar
ChanceWarren
No, I don't think superglue would be sufficient. The only suggestion I can come up with is to get a hole drilled and tapped in your "destroyed" key. Maybe dremel the engaging surfaces to look more like the Rogue key (NOT THE KEYS NOTCHES!) Of course, if it were me, I would have bought a blank Rogue key and had it cut to match my Z key then reprogrammed/switched chips.
Old Oct 20, 2009 | 06:56 PM
  #42
o2sys's Avatar
o2sys
that would have been the easy expensive way, no fun then lol
Old Oct 20, 2009 | 07:52 PM
  #43
Resmarted's Avatar
Resmarted
Originally Posted by o2sys
Could i just super glue it in there? Any suggestions?
Make 2 holes, get another similarly sized screw, and make another mounting spot. To make the mounting spot, get some kind of plastic like epoxy maybe? I know there is some plastic equivalent of JB weld......... Make a little mound of the epoxy and start the hole a little bit. Then when you screw the screw in, it will cut its own thread.
Maybe if you posted a pic of the inside of the key I could tell the clearances a bit better...
Old Oct 22, 2009 | 04:53 AM
  #44
Lcat84's Avatar
Lcat84
I just picked one up myself yesterday...how easy was it to transfer the transponder chip?
Old Oct 22, 2009 | 04:55 AM
  #45
tranceformer95's Avatar
tranceformer95
It can be tricky removing the chip from one of the primary keys. When I did my swap, I ripped apart the valet key because it looked easier.
Old Oct 22, 2009 | 12:35 PM
  #46
nismo_nate's Avatar
nismo_nate
i just ordered my switchblade key! i'll post mine in 2 weeks lol
Old Oct 22, 2009 | 12:45 PM
  #47
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
Old Oct 22, 2009 | 01:24 PM
  #48
tinlok's Avatar
tinlok
^ lol! nice keys
suckers flip keys while you're flipping ki's
Old Oct 31, 2009 | 02:27 PM
  #49
volcomfaraz's Avatar
volcomfaraz
ahh best 19.99 i've spent all month! key was purchased from a.suntek on ebay. shipping time is estimaed at 14-21 days but it arrived in 10. i must say, im quite impressed with the quality. the install was super easy--15 minutes tops(5 minutes for transferring circuit board/battery and 10 to get the transponder out). home depot cut the key for free, as they only charge u for purchasing the blank when making copies.
only issue is that i can't get any sort of key ring through the bottom to attach the rest of my keys to. otherwise couldn't be happier!
Old Oct 31, 2009 | 03:17 PM
  #50
o2sys's Avatar
o2sys
no more switchblade key!
Old Nov 2, 2009 | 12:54 PM
  #51
Evilmexicaninus's Avatar
Evilmexicaninus
nice =)
Old Nov 2, 2009 | 01:22 PM
  #52
o2sys's Avatar
o2sys
Yes, much more lighter and portable!
I didn't want to spend $80 on new Rogue Key so i bought a cut used one for like $10.
Then i hacked my existing key and glued it in there with a plastic weld/epoxy.
Old Nov 2, 2009 | 01:23 PM
  #53
Kwame's Avatar
Kwame
So if you have the Rogue Key you are essentially giving up the ability to open your hatch with your remote, am I correct?
Old Nov 2, 2009 | 01:46 PM
  #54
350Speed's Avatar
350Speed
Correct.
Old Nov 2, 2009 | 01:54 PM
  #55
o2sys's Avatar
o2sys
Yes, but to justify this i say to myself, in order to open the hatch you need to walk up to the car anyways to lift it open (since its not automatic in our cars)...so giving up the button wont be a big deal anyways
Old Nov 2, 2009 | 03:05 PM
  #56
ZS14RR's Avatar
ZS14RR
I have the same one as the OP
Old Nov 3, 2009 | 05:01 AM
  #57
Lcat84's Avatar
Lcat84
Yup mine, finally came in and got it cut.
same as OP...I like it.
Old Nov 4, 2009 | 10:57 AM
  #58
350Speed's Avatar
350Speed
I just recieved mine in the mail from a.suntek. Can't wait to get it installed tonight.
Updated: Got turned down by Home Depot & Lowe's, so decided to take it to Locksmith. The guy did it in 2min for free. The key looks nice and solid.
Thanks everyone.
Old Nov 7, 2009 | 08:59 AM
  #59
Khanvict's Avatar
Khanvict
can someone please post a DIY link for the first key in this post? i tried searching but no luck! i remember seeing it on here somewhere but for some reason i cannot locate it. thanks!
Old Nov 7, 2009 | 12:34 PM
  #60
BakaN20's Avatar
BakaN20
Did you check the diy section? Probably not.
https://my350z.com/forum/audio-video...-flip-key.html
