Instruction to take off arm rest
Old Nov 9, 2009 | 09:52 AM
xthejokerx's Avatar
xthejokerx
Default Instruction to take off arm rest
Is there a DIY somewhere for removing the interior arm rests on the doors? Thx
Old Nov 9, 2009 | 10:16 AM
zakmartin's Avatar
zakmartin
On the '06-'08, start from the rearward side of the arm rest and pull straight up. They'll pop right out.
Edit:
I'm pretty sure your year works the same way.
Old Nov 9, 2009 | 10:52 AM
hellsoldiers08's Avatar
hellsoldiers08
Ya, in the DIY section, if you would of searched you would of easily found it.
Old Nov 9, 2009 | 11:47 AM
lbz's Avatar
lbz
05 not the same as 06 - 08.
Inside the area that is depressed down, kinda like a cavity, is a small round cover, pop that with a small flat blade screwdriver.
That will reveal a small screw that you have to remove.
Once that is out, you can pop up the assembly.
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
nanotech
Oct 2, 2015 05:02 AM
