Gauging interest: CF full Body kit/Front Diffuser project...
Old Oct 20, 2003 | 10:36 AM
abstrakt's Avatar
abstrakt
Hey Cheston...I should have known the Aug timeframe you gave me earlier was too good to be true...LOL...I'm still interested though, but now only in the rear diffuser. Can't wait to see it...Thanks for making things happen for the Z...
Aby
Old Oct 21, 2003 | 08:46 AM
John's Avatar
John
I'm interested, but at $550 for a front diffuser, I think it's overpriced. Other CF diffusers are going for a little over $400, and even that is overpriced IMO.
Old Oct 21, 2003 | 12:01 PM
jran76's Avatar
jran76
The Top Secret diffuser goes for closer to $700-800. I also think it is more functional than most on the market.
Old Oct 21, 2003 | 12:20 PM
John's Avatar
John
The C-West c/f diffusers appears to be functional as well, but costs just over $400 (prices have come down drastically)...
Old Oct 21, 2003 | 12:49 PM
whatever's Avatar
whatever
Veteran
Originally posted by john350Z
btw-have you thought of just making a front bumper with lip and sideskirts that fit the 350z without flares like the original 350z gt-car? the original rear gt-wing in carbon fiber too!!!!!!!!
I 2nd John's suggestion. I would be interested in a real full cf kit of the GT car or a full cf kit of the JGTC 350Z
Old Oct 22, 2003 | 04:47 AM
quangquoclu's Avatar
quangquoclu
Newbie
im interested in the front and rear diffuser. Youll have my vote.
Old Oct 22, 2003 | 05:41 AM
MY350Z.COM's Avatar
John, the reason why the TS style diffusers are more expensive is because they reach way underneath the car, they replace the factory plastic cover. That's how large of a piece it is. Thus justifying the cost.
Old Oct 22, 2003 | 08:04 AM
Chebosto's Avatar
Chebosto
yea. the front diffuser is not just a lip addon lke the Cwest is, which in theory is actually a front splitter, this is a full diffuser, which channels air flow underneath the car, its size is relatively the side of your hood, just, underneath the car... hence the cost, which is, relatively cheap for the materials and compeition's pricing..
picts soon
Old Oct 22, 2003 | 08:12 AM
ckny's Avatar
ckny
cheston - definately interested in front and rear diffusers (i need to get the greddy twin can exhaust when it comes out so i should have some nice room back there) =)
Old Oct 22, 2003 | 09:11 AM
John's Avatar
John
Thanks for the clarification.
Old Oct 22, 2003 | 10:56 AM
little_rod's Avatar
little_rod
Yeah, I think I agree with most people on the rear diffuser. Alot of people have aftermarket exhaust, and this causes a huge hole in the rear of the car. Will this rear diffuser cover all exhaust systems, meaning stock and aftermarket??? And what kind of functional numbers will you provide(if available)???
Old Oct 22, 2003 | 11:09 AM
Chebosto's Avatar
Chebosto
since i dont have a windtunnel for a car readily available *who does? ;P * i can only estimate the amount of drag and/or lift coeficient reductions based on the angles of the diffusers...
the rear is going to be hard to make everyone happy, simple put that there are so many exhausts, not everyone will be able to use what i eventually put out... but yea.. the single canister and or dual canister designes leave ample room up behind the rear bumper for some cool diffuser designs.....
the main goal of a rear diffuser is to smoothe the air flow out and angled up and away from the ground.. a simple 4 degrees of incline of a flat surface (such as the surface of the rear stock muffler) can decrease rear lift by .1-.2 based on speed and location relative to the rear axles...
Old Oct 22, 2003 | 12:09 PM
little_rod's Avatar
little_rod
Almost as if you are saying stay stock or go with a canister design for aerodynamic purposes with your diffuser. I do know one thing, Nissan has a wind tunnel, and they did test the stock exhaust. Hopefully some of the aftermarket manufactors took that into consideration also.
You would open your market up more, with the rear diffuser being able to fit more vehicles, of course.
Old Oct 22, 2003 | 12:48 PM
havabooz's Avatar
havabooz
umm..please make it so it can fit the angled tip injens...please
i have a question though...assuming the rear diffuser you made was very close to the exhaust tips...would the heat ruin the CF?
Old Oct 22, 2003 | 12:55 PM
Chebosto's Avatar
Chebosto
depends on the resin mixture that is used.. the CF isnt going to be wrapped around the exhaust, just near it. there should be enough air flow to cool around the exhausts if i can get the diffuser correctly set... besides typically the rear diffusers are supposed to be functional.. i dont think you're gonna stick your head underneath to look at it all the time.. it will probably be dirty from the road scum.
Old Oct 22, 2003 | 02:19 PM
havabooz's Avatar
havabooz
will the rear diffuser have any asthetic purpose or is the hole piece non-visible?
Old Oct 22, 2003 | 03:08 PM
milner's Avatar
milner
i want the front def, and would love a rear one , but
will the angeled injen exhaust fit
if it fits that would be great
Old Oct 22, 2003 | 04:22 PM
  #38
havabooz's Avatar
havabooz
you know what i just realized....so many NJ ppl have the injen....im a NJ resident so i guess that counts ...but seriously...whats the deal with that
Old Oct 23, 2003 | 06:15 PM
  #39
reen's Avatar
reen
The purpose of a rear diffuser is to let the compressed, fast-moving air from underneath the car slow and expand before it leaves the underside, creating a low-pressure area. This low-pressure area effectively "pulls" the rear of the car down (in laymen's terms) reducing lift, or, if there is no lift, increasing downforce. For an obvious example look at the rear of an F1 car.
A truly functional rear diffuser is a great thing at high speeds. Keep things balanced F/R with a good front splitter though.
Plus, there's the fact that it looks bitchin'!!!
Old Oct 24, 2003 | 06:53 AM
  #40
Chebosto's Avatar
Chebosto
what would be really cool is a smooth underbody, then you can truly control the airflow.. but.. finding mount points would be interesting...
