The Official Shift Knob Thread
Old Nov 9, 2015 | 03:31 AM
  #421
craig12895's Avatar
craig12895
Since the wood **** is gaining interest, I shall supply more pictures
Keep in mind these are all unedited cell phone pics
Old Nov 9, 2015 | 04:17 AM
  #422
sofakiing's Avatar
sofakiing
NOT TK
IBA_5332 by sofa king, on Flickr
Old Nov 9, 2015 | 02:58 PM
  #423
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
Ok got my knobby starter kit.. Now just need to make some...
Did you make the wood ****? Do you know what species of wood it is?
Old Nov 9, 2015 | 05:02 PM
  #424
Fridge Gnome's Avatar
Fridge Gnome
Just ordered a Lathe Werks piston, can't believe I just spent that much on little waggle stick
Old Nov 9, 2015 | 06:34 PM
  #425
HRMoneyPit's Avatar
HRMoneyPit
Craig you need some type of retainer in between the shifter boot and ****
Old Nov 9, 2015 | 06:54 PM
  #426
craig12895's Avatar
craig12895
I actually had a nismo shift **** prior to this one and I had the collar that is made for the nismo. I put that on with the wood but didn't like it. Haven't found one I really like to contrast the wood so I just put a washer under the shift boot that keeps the boot up tight against the wood.
And I can post on here tomorrow about the place that made mine. They allow you to do choose whatever shape/color wood **** you want
Old Nov 10, 2015 | 06:21 AM
  #427
HRMoneyPit's Avatar
HRMoneyPit
Maybe just a simple black collar?
Old Nov 10, 2015 | 10:35 AM
  #428
craig12895's Avatar
craig12895
I just wasn't ever too crazy about anything. The I feel like anything under it takes away from the wood. And once I did the washer mod thing I just kinda never looked back.
For anyone interested, this is where my wood shift **** came from
https://www.etsy.com/shop/SilverfoxWoodStudio?page=1
Old Nov 10, 2015 | 12:09 PM
  #429
dboyzalter's Avatar
dboyzalter
Went to woodcraft got some blanks... We will see how this plays out.
Old Nov 10, 2015 | 03:54 PM
  #430
HRMoneyPit's Avatar
HRMoneyPit
I like all of them! What's the cost? What's your design looking like?
Old Nov 10, 2015 | 04:12 PM
  #431
dboyzalter's Avatar
dboyzalter
The cherry one I plan to make a big ball, the others are a bit skinny so im going to try and make them similar to my nismo size and shape. Ive never used acrylic before so I am going to experiment with that...
Im having some trouble getting my lathe set up once I work out the kinks hopefully I can get some made...
The nuts at 72 cents... The wood varies. Got the cherry piece for cheap and the other piece was $2. The acrylic pieces are like $10-15 depending on the size. They had ab awesome red and black one but I figured I would see how this small one goes before I get too carried away.
Old Nov 10, 2015 | 06:26 PM
  #432
HRMoneyPit's Avatar
HRMoneyPit
Looking forward to an update
Old Nov 11, 2015 | 05:02 PM
  #433
dboyzalter's Avatar
dboyzalter
Instead of blowing up this thread I just made a DIY that most people will not have the tools to do... So ill probably keep that one updated...
https://my350z.com/forum/body-interi...l#post10679689
Old Nov 11, 2015 | 05:19 PM
  #434
HRMoneyPit's Avatar
HRMoneyPit
I like the idea of using this thread better
Old Nov 11, 2015 | 05:35 PM
  #435
dboyzalter's Avatar
dboyzalter
Well if I make something real impressive I'll post it up in here but between
And the finished product it will be in the diy.
Old Nov 12, 2015 | 10:08 PM
  #436
mcubed45's Avatar
mcubed45
Stainless Steel Piston from Lathewerks w/ custom engraving
Old Nov 13, 2015 | 04:40 AM
  #437
HRMoneyPit's Avatar
HRMoneyPit
I like that one
Old Nov 13, 2015 | 06:47 PM
  #438
DAgrizzly2's Avatar
DAgrizzly2
Default problem getting original **** off
has anyone had problems getting the oem shifter **** off? I just tried to get mine off, I took off the climate console and the trim around the shifter. I put tape around the metal part of the shifter lever under the leather boot and attached a vice grip to it and tightened it all the way. Also taped the bottom metal part of the original shifter **** and attached another vice grip to that turning it counter clock wise while trying to keep the lever still so i wouldn't damage the transmission in any way but the lever still seemed to turn and my OEM shifter eventually cracked and the gear map on the top popped off due to the pressure. After that I decided to give up for the time being. Has anyone had similar issues removing their shifter ****? I have a 2003 which I've heard is more difficult for whatever reason. If anyone can offer suggestions on how to remove the original please let me know I'm desperate to get it off and put my new one on.
Old Nov 14, 2015 | 09:38 AM
  #439
NoQuestionZ's Avatar
NoQuestionZ
Since it's already torn up,cut it off. Or keep twisting it.
Old Mar 26, 2016 | 02:20 PM
  #440
dboyzalter's Avatar
dboyzalter
My newest creation.
