A/C control question.....
Old Dec 12, 2009 | 03:36 PM
the_dood's Avatar
the_dood
Default A/C control question.....
This might be far fetched but does anyone find it annoying how the air conditioner comes on automatically when you turn on recirculate and put it on auto or anything.
I was driving through a tunnel yesterday and i switched to recirculate and i couldn't have it on without the ac coming on too, and its frikken 23 degrees F outside. It also comes on when i put it on defrost too, so i constantly have to take off the ac all the time.
I have an 03 so i know other people hopefully have the same thing happen to them.
Im assuming there is no way to bypass this is there?
Old Dec 12, 2009 | 04:17 PM
F34RL355's Avatar
F34RL355
yeah i find the ac annoying too seems to always be on when i turn car on etc.
Old Dec 12, 2009 | 08:24 PM
corrado15's Avatar
corrado15
Glad you posted this - I thought there was a fault with my AC since it does the same thing...
Davy
Old Dec 13, 2009 | 12:06 AM
MikeBit's Avatar
MikeBit
lol just push the damn button that turns the AC light off. haha. but yeah... i guess it would annoy some people
Old Dec 13, 2009 | 04:24 AM
1GR8350Z's Avatar
1GR8350Z
It annoyed me so bad I thought about driving it off a cliff.
Old Dec 13, 2009 | 04:57 AM
KornerCarver's Avatar
KornerCarver
I just set the thermostat at 75 degrees and let the car decide whether to heat or cool. It keeps the interior very comfortable.
Old Dec 13, 2009 | 11:14 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
I've made it a habit of turning the blower off when I get out of the car so the a/c doesn't come on when I start it.
Old Feb 9, 2010 | 04:57 AM
cellude's Avatar
cellude
After having just disabled this auto-compressor-on feature on the Fit I am even more interested in finding a way to do this in the Z. I do like the idea of actually being able to control if I want to have the compressor off/on while recircing the air.
Link below for ideas;
http://www.fitfreak.net/forums/2nd-g...c-defrost.html
Old Feb 9, 2010 | 05:49 AM
maXmood's Avatar
maXmood
Under Boost!
turn the AC off, and press the recirc. this should keep everything off.
'06 here and that's how i do it.
Old Feb 9, 2010 | 06:11 AM
rotchcrocket04's Avatar
rotchcrocket04
Davy
I thought the same thing but never cared enough to search to see if this is the same in every Z.
However, it still clicks the compressor on (you can hear it) which seems completely unnecessary if I'm going to turn it right back off - especially in conditions like this.
Old Feb 9, 2010 | 06:49 AM
Zazz93's Avatar
Zazz93
There is something in the factory service manual about the auto AC function, I didn't read it very closely, but it goes in to detail about the function. I would imagine the engineers set it up that way to deal with the way the basic venting is set up. I've noticed without the AC on the air literally feels stale (moreso than any other car I've had) and to combat this along with promoting better defogging the AC conditions the air (hot or cold).
As a side note, did you ever wonder why the car didn't seem to lose a lot of power when the AC was on? Read below for the answer...
(From the FSM)
This system improves engine operation when the air conditioner is used.
Under the following conditions, the air conditioner is turned OFF.
  • When the accelerator pedal is fully depressed.
  • When cranking the engine.
  • At high engine speeds.
  • When the engine coolant temperature becomes excessively high.
  • When operating power steering during low engine speed or low vehicle speed.
  • When engine speed is excessively low.
  • When refrigerant pressure is excessively low or high.
Old Feb 9, 2010 | 07:25 AM
o2sys's Avatar
o2sys
air conditioning does not mean COLD air, just because you turn your a/c on during summer doesn't necessarily mean its only for cold air. Its the freeon that makes cold air. During winter in conditions the air not cool it.
And the above FSM notes are all true. Ever put your a/c **** in AUTO when you just started the car? It wont blow air till its ready.
Old Feb 9, 2010 | 07:36 AM
rotchcrocket04
Theoretically, if the A/C light is on - wouldn't it still be using the A/C compressor then? Wouldn't that be a waste if it doesn't need to blow cold air?
I'm asking serious questions here... I'm not sure
Old Feb 9, 2010 | 07:37 AM
Zazz93's Avatar
Zazz93
What I've done in the past is leave the fan in the lowest setting and turn off the AC. Once you turn on the car it will not auto start the AC unless you ask for it or turn on the defogger which mandates the use initially.
Old Feb 9, 2010 | 07:43 AM
JCat's Avatar
JCat
I do not know if this is true.....but an engineer once told me that unless you circulate the freon (or whatever) and run the compressor occationally, the system will go bad.
This is why the air conditioner is cycled on (but the air isn't used) during windshield defrost (on certain vehicles).
Old Feb 9, 2010 | 08:10 AM
Zazz93's Avatar
Zazz93
Next time the conditions allow, try using the defogger with AC on and then off. See which one works the most efficent. Its pretty obvious to me why Nissan did it but I do wish there was a way to easily disable it. The constant on and off of the AC has to be bad on the clutch and compressor.
sales@czp
Sep 23, 2019 03:30 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
