Installing New Shifter Knob... how?
I was deciding on getting a new shifter **** for my stock 07 Z, but wasnt sure how complicated it is to take the stock one off? and install a new one???. Is it a pain to do so? I couldn't find any thread (with pictures) on this so anyone can help me out.. that would be great... thanks!!!
Deff easy as pie...
1st. To take the trim off. Push down nd pull back and up on the shift boot, the trim should pop right off (jJust don't pull the boot completely off because there is a wire that goes to the temp ***** that easily rips).
2nd. Then hold onto the shift linkage so it doesn't move (you want to do this or it will screw with the tranny).
3rd. Then twist the **** off. I didn't need to use vice grips but they will help if it's too hard to twist off.
4th. Put the shift **** and any other pieces onto the shifter and screw on (you should still be holding onto the linkag).
5th. Pop the trim back in and your done
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
