2006 parking light replacement
Old Feb 18, 2010 | 05:41 AM
JGZ350's Avatar
JGZ350
Default 2006 parking light replacement
I've done a search on this, but could not find any information on a replacing the parking lights on a 2006+ 350Z. Is this the same procedure as doing it on a 2003-05 Z?
Just for kicks, I called several Nissan dealers and they all want to charge one hour of labor for this job. Are you kidding me??? What a joke.
Old Feb 18, 2010 | 06:07 AM
Z04's Avatar
Z04
take out the old parking light and put the new one in. in the time it took you to search and wait for an answer you could have been done already.
Old Feb 18, 2010 | 06:28 AM
importdemon5's Avatar
importdemon5
I'm gonna assume that you can't get to the bolts that are under the front bumper? I have an 04 and you can't take out the headlight unless you take the front bumper off which is a big PITA.. What I did was took of my wheels on the front and removed the plastic wheel well covers (like 8 screws in the well and 4 underneath the front bumper) and just popped the light out of the socket. Took me about 30min to do since I didn't know what I was doing at first. Took me about 5min to remove the second wheel well cover and put it back on.
Old Feb 18, 2010 | 07:04 AM
JGZ350's Avatar
JGZ350
Will that same procedure work on a 2006+ 350Z? I've also read that you can turn your wheel in all the way, jack up your Z and remove 2 screws and 3 clips on the fender liner. Then pull it back enough to gain access to the parking light.
Old Feb 18, 2010 | 07:31 AM
diablox1's Avatar
diablox1
....I have an 04 and you can't take out the headlight unless you take the front bumper off which is a big PITA..
I disagree on the PITA part.... takes me 15 mins to remove the front bumper.
having said that... to simply replace the parking light bulb is quick and easy. jack the front of the car up. get a small phillips screw driver (to fit between your fender and your wheel, otherwise remove the wheel), and remove the front 2 or 3 screws from the plastic inner fender lining. pull it back a bit with one hand, reach in with the other hand and undo the bulb. done.
I have an '07 redline.
Old Feb 18, 2010 | 01:03 PM
User 42426's Avatar
User 42426
taking off your bumper takes a max of 10 minutes. You just jack it up, unscrew the bottom bolts, side bolts, and take out the top plugs. But if you don't want to take off the bumper, like everyone said, just jack it up, take bolts off side fender, stick your arm in, tight squeeze, and twist the handle holding the parking bulb and replace.
Old Feb 18, 2010 | 04:24 PM
Get_Zwole's Avatar
Get_Zwole
is there anyway to get the ugly orange brown reflector off? I wanna change the lights but get that piece of plastic off too.
Old Feb 19, 2010 | 04:09 AM
cheshirecat79's Avatar
cheshirecat79
If you're talking about the front bumper reflector, you'll have the easiest time just taking the front bumper off and removing them that way. They are very easy to remove.
Others have taken them off with the bumper mounted, but I personally think that would take too much effort.
Old Feb 19, 2010 | 04:40 AM
Z04's Avatar
Z04
actually i think he may mean the square bulb cover that is inside the light housing itself on the 06+ lights. if that is it then the only way to remove it is to open the housing up comletely and take it off, then reseal. of course if you are going to go that far for a piece of plastic then you might as well paint them and make it worth the effort
Old Feb 19, 2010 | 05:47 AM
Get_Zwole's Avatar
Get_Zwole
Yeah thats what i was talking about, that sucks thanks for the response. Guess ill just leave them be for now.
ablaine
Nov 29, 2016 10:13 AM
samansharif
Sep 25, 2015 12:31 PM
