Mishimoto Fan shroud
Old Mar 19, 2010 | 02:06 PM
robbinsj's Avatar
robbinsj
Default Mishimoto Fan shroud
Just got this in and was wondering if anyone else that is running this on there Z could give me some feedback on quality and dependability. I am running a turbo and want to know how much I am going to have to watch to make sure it is kicking on right. After all I don't want to over heat, I am in fl.
Mods pls move if in wrong section.
Old Mar 19, 2010 | 04:09 PM
ImWeeZzel's Avatar
ImWeeZzel
i havent had any problems w/mine but the weather hasnt gotten hot yet... theres acouple of guys in the thread "issues with mishimoto fans" who've had problems w/ overheating
Old Mar 19, 2010 | 05:59 PM
robbinsj's Avatar
robbinsj
yea was what I thought was hoping to get someone to pipe in.
Old Mar 20, 2010 | 07:59 AM
robbinsj's Avatar
robbinsj
Anyone know how to connect this thing???
Pics of OEM and the mishimoto. Seems they have only a ground and power.
Attached Thumbnails Mishimoto Fan shroud-picture-001.jpg   Mishimoto Fan shroud-picture-002.jpg
Old Mar 21, 2010 | 08:50 AM
robbinsj's Avatar
robbinsj
Anyone else running this in there Z?
Old Mar 21, 2010 | 09:00 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
if you search, there are at least a couple threads on it, one of which went into the install
Old Apr 1, 2010 | 07:31 AM
robbinsj's Avatar
robbinsj
I have searched and there is only info on using the OEM wires that I do not want to destroy. I have contacted members that have this with no responce so wtf I will bump this and ask again.
Anyone know how to wire one of thes SOB's???
I found the diagram for it but I do not understand the 5 prong relay settup. Please post up or pm me. I need to get this done so I can drive my Z.
Oh and Timmy go back to biting your ear. Your not helpfull and your correspondace/service as avendor $uck$.
I will get my hebi bebi elseware.
Old Apr 1, 2010 | 07:37 AM
ImWeeZzel's Avatar
ImWeeZzel
I sent you back a PM, even though I have no clue on how to wire these bad boys because I had Fail Safe performance do it for me. Im going home within the next 15 days, if you still them I will gladly jack my car up and post mad amounts of pics. Im sorry I couldnt be of much help.
Old Apr 1, 2010 | 07:42 AM
Z1 Performance
Former Sponsor
I was simply advising that I recalled seeing at least 1 install thread. If it's not a helpful thread then do be it...that's not my fault
I'm not interested in selling you anything so don't worry Jr my feelings aren't hurt
Old Apr 1, 2010 | 07:43 AM
robbinsj's Avatar
robbinsj
NP firend and I thank you for your help. If you could locate the poser wire and track it with pics I would appreciate it greatly. tyvm sir!
Old Apr 1, 2010 | 07:56 AM
robbinsj's Avatar
robbinsj
If you stated it like this "I recalled seeing at least 1 install thread." then I would understand but instead you start with this "if you search". Not saying because the thread was not helpfull that it is your fault just confirming why this "one of which went into the install " does not help.
Sounds good to me little Timmy but if your feelings where not hurt then what propted the 11min reply. What was the rush???
Actions speak louder than words and your reply timing is screaming the other way.
Do you speak to all potential customers this way??? Must be why you have the time to lurk the threads.
Oh well, will bring me plesure to enlighten others to the way you handle yourself and potental customers.
Old Apr 1, 2010 | 08:17 AM
Z1 Performance
Former Sponsor
hopefully you find the info you need; I'd give it to you, but you frankly don't deserve anymore of my time
eh screw it, I'm a better person than you are
https://my350z.com/forum/engine-and-...ator-fans.html
Was the thread. Seems to cover the install correctly
Old Apr 1, 2010 | 08:40 AM
robbinsj's Avatar
robbinsj
Well thanks, appriciate the differant stance and sarcasim but yea thats the thread I was refering to with the OEM fan wires. The setup I want is the one recommended by Mishimoto here http://www.clubcivic.com/board/showthread.php?t=181750 but I can not understand the 5 post relay and the diagram.
Anyone understand this?
The OP of that thread was the member I pmed without reply as well.
Old Apr 1, 2010 | 08:51 AM
robbinsj's Avatar
robbinsj
Anyone understand 5 prong relays and where where do I attach what. Also what is the accessory wire that I have to tap into?
Old Apr 1, 2010 | 10:21 AM
solar_n_orange's Avatar
solar_n_orange
the12volt.com
Here is a link to relays from a really good site on all things pertaining to wiring in a car. This is where I look to for advice anytime I'm having trouble wiring things like car alarms. A simple search on this site should come up with the pin-outs and what they do on the relay.
Sorry I couldn't be of more help but I lost most of my wiring diagrams due to a hard drive melt down.
Old Apr 1, 2010 | 10:44 AM
solar_n_orange
This looks like it should work for your setup.
Pin 86: Tie this into factory wiring that switches the fans on. (someone else may know which wire this is)
pin 87: Of course take this to the battery with a fused connection.
Pin 85: Chassis ground. Be sure it makes contact with bare metal.
Pin 30: This connects to whatever wire kicks on your fans.
I know you don't want to chop into the factory wiring but you need a remote turn on lead of some sort. And be sure to use a fuse going to the 12v+ line. Your fans should tell you how many amps of current they draw.
Hope this helps. It's been quite awhile since I've been wiring relays and other crazy stuff.
To make life easier get one of these:
Just Google 5 Pin Relay Harness to find one.
Old Apr 1, 2010 | 11:08 AM
robbinsj's Avatar
robbinsj
Originally Posted by solar_n_orange
the12volt.com
np, tyvm this is great help!
Old Apr 1, 2010 | 11:13 AM
robbinsj's Avatar
robbinsj
Perfect, TYVM!
mjgfish
Sep 22, 2015 05:55 AM
