What brand harness do you like and why?
Old Nov 4, 2003 | 07:15 PM
MY350Z.COM's Avatar
I'm going with the Schroth Profi III because Steve said so.
Old Nov 4, 2003 | 07:34 PM
raceboy's Avatar
raceboy
Hey, I just bought the Schroth because the yellow on the harness matched the yellow writing on my seat!
Old Nov 29, 2004 | 04:16 PM
daveh's Avatar
daveh
What about the g-force harness? While the latch isn't as easy to use as the schroth, They cost much less and are SFI approved. Any comments?
http://www.racerwholesale.com/Mercha...Code=Harnesses
Can you safely use an antisub belt with stock seats?
This Profi II ASM schroth harness seems like it might be a good alternative for those with a stock seat with the anti-sub technology.
http://www.hmsmotorsport.com/store.p...321&method=cat
Old Nov 29, 2004 | 08:30 PM
EnthuZ's Avatar
EnthuZ
"Can you safely use an antisub belt with stock seats?"
YES! IF mounted correctly. I mounted mine at the same attatchment points as the lap belt mounts. It's PCA approved!
See www.BCRLtd.net for pix.
Do NOT mount them to the front seat frame attatchments.
Man, this is an OLD thread!
PS, I have a better solution with custom Impact Racing belts.
Old Nov 30, 2004 | 09:47 AM
daveh's Avatar
daveh
I just talked to HMS and they said you shouldn't use a 5 or 6 pt with a stock seat because you will not get the correct geometry. The sub belt should be pulling down. With a stock seat it will be pulling forward which is exactly what you are trying to prevent. I explained how enthuz set his up (sitting on the sub belts) and he said that some formula belts are set up like this but he still thought that the ASM 4pt belt was a safer solution.
Just some food for thought. I'm trying to do the safest thing possible.
I really wish the www.BCRLtd.net site had some pictures of those impact racing belts.
Old Nov 30, 2004 | 11:49 AM
s0nz's Avatar
s0nz
my takata does the job...
i havent tried those other harness's..
Old Nov 30, 2004 | 12:00 PM
EnthuZ's Avatar
EnthuZ
"I really wish the www.BCRLtd.net site had some pictures of those impact racing belts. "
So do I!
I'll see what my 'WEB-MASTER" can do.
In the pix, you can see how I run the sub belts under the seat back, so there is no way that one could slide forward.
In the mean time:
Old Nov 30, 2004 | 01:41 PM
ZxRage's Avatar
ZxRage
What kind of harness is that the ib 6? Who makes it?
Old Nov 30, 2004 | 02:21 PM
LaidbackRacr's Avatar
LaidbackRacr
I like sparco cam lock harness I have also had there standard harness, glorified seatbelt. Cam lock is extremely secure I like the thick and wide harness. though i have only tried sparco (matches rest of interior mods)
Old Nov 30, 2004 | 02:23 PM
EnthuZ's Avatar
EnthuZ
It is a BCRLtd custom made Impact Racing harness. The 350Z requires non standard belts to work as I have installed them.
Impact Racing is Bill Simpson's new company after getting f*cked by NASCAR & the Earnhart family.
BTW, I just checked a couple HPDE web sites, PCA & Car Guys, and they both do NOT allow 4 point harnesses. Must have a 5 or 6 point harness. The Chicago PCA site also requires 5 or 6 point harnesses to run their HPDE at Road America (and a Porsche ).
Old Dec 4, 2004 | 12:03 AM
MarquisDeSam's Avatar
MarquisDeSam
SCHROTH all the way. I have em paired with my Cobra Suzukas. They cost a bit more than the others, but they have a FIA life of 5 years over 2, which is the standard for others. Plus the polyester webbing is 30%-ish less prone to stretching.
Old Dec 4, 2004 | 10:54 AM
daveh's Avatar
daveh
I'm going to go with the 4pt that I listed above because according to hms (schroth importers) it is the safest thing for the stock seats. For less than $20, I can add the sub straps to this system if I ever get a race seat.
HoBrahYouStink
Jun 24, 2016 10:58 PM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
