Need help on headlights... Projector/HIDs
Old May 18, 2010 | 02:26 PM
Romanteni's Avatar
Romanteni
So I don't have my oem ballast. So I need to get an HID conversion kit with bulbs. Question now is, which one? I really like the look of these black lights way more then stock 03-05 ones. Just need to convert them now. Anyone knows a good kit they've used?
Old May 18, 2010 | 03:19 PM
loudrims_inc's Avatar
loudrims_inc
dammit, no one quoted the ex???
Old May 18, 2010 | 05:25 PM
nismo1234's Avatar
nismo1234
Default headlight
whats up u probably have a base model 350z right... i had the same problem with my headlights. the new harness wont fit the stock harness. anyway i got the different style harness from my friends 350z and rewired my headlights i have old headlights if you would like they should fit perfectly if you need anything just pm me.
Old May 18, 2010 | 07:09 PM
Romanteni's Avatar
Romanteni
no its touring car. thats why i need to convert lights from reg to HID. my car connector is HID. so.
Old May 18, 2010 | 07:23 PM
TheFarmer's Avatar
TheFarmer
What happened to your OEM ballasts? Torched?
Old May 20, 2010 | 07:46 PM
Romanteni's Avatar
Romanteni
Yeah, they torched it, and looks like knew what to do, and they broke pretty much everything.
Here's another question I stumbled upon. I'm trying to see how to hook this stuff up ( I got a conversion kit, right bulbs right everything. Now, I'm confused where to connect the turn signals. Here's the confusion and picture to it. Left side has 3 connectors coming from the car, but right side has only 1. (drivers).
here's the picture. To better explain I put numbers.
The bigger blue one- both pass and drivers have em
the 2 other smaller- only on passenger side, as I took this picture on passnger. Drivers side only got 1 of those blue connectors... no turn signal connectors?
the headlights seem to only have 1 connector and the turn signals and low beams connect to one... Where Do I connect the turn signals? LOL. I know its a weird question, but maybe if someone can tell me what those 2 other connectors on passenger side are, I can figure it out from there.
Old May 20, 2010 | 11:52 PM
_ink's Avatar
_ink
Do the headlights that you purchased hook up to these plugs??
Old May 21, 2010 | 06:07 AM
Romanteni's Avatar
Romanteni
No,I bought projectors, which I like how they look, and I'm switching out bulbs to none HID. What I'm wondering is what those 2 other connectors are on passenger side
Old May 24, 2010 | 04:35 PM
Romanteni's Avatar
Romanteni
So I got the kit, everything in place. Now wiring issue. the diagram that came with it has wrongly colored wires. So now im not sure which OEM HID connector wire is for what. There's total of 8 wires in the connector, so some are lowbeam, high beam, turn signals and power/ground. anyone knows which wire is what?? let me know plz
Ktm47
Interior
13
Jan 30, 2013 10:31 AM
baileyrx
Photoshop
Jan 8, 2012 08:07 PM
wardz33
Pacific
Dec 21, 2008 10:00 AM
