Customized stock hood?
Old May 20, 2010 | 07:13 PM
adamc's Avatar
adamc
Originally Posted by maXmood
thanks for the tip..
i have put in a Nismo thermostats, but didn't actually get it programmed.
yea on my trans am I changed the thermostat out first... and it still got hot as hell.. it wasnt till I got the car tunned and the fan temps changed that I noticed a huge difference.. when you go to get the car tunned be sure to tell them that you want your fan kick in temps lowered.. or they may not do it.. i had to tell them for mine.. but yea, after it was done the fans did kick on alot more but the car never got to the point that it was to hot that it couldnt be cooled down... thermostat alone without the fans being programmed helps very little
i think it will help you tons.. and about those slots in the oem hood... i dont see it being possible unless u stripped the paint.. and used something like a plasma cutter... then ud have to paint it all over again.. as u couldn't plasma with paint.. and it would burn off surrounding paint when used..
so all that trouble i think ud be better off buying a fiberglass / carbon fiber hood.. then doing it or buying one that it was already done on
Old May 20, 2010 | 10:41 PM
maXmood's Avatar
maXmood
Under Boost!
thanks for the heads up.. i'll make sure my tuner knows about the thermo.
regarding the hood, customizing the stock (cutting + painting) would be cheaper than getting a CF one.
CF hood would cost me about $1200+, while modifying the stock one won't cost more than $600
once i'm done with my FI setup, i'll buy a CF to complement the look/power.
Old May 21, 2010 | 02:06 AM
hpka365's Avatar
hpka365
http://www.cvrmotorsports.com/store/...ategory_id=908
and if you put in the discount code on the site at checkout it takes off 16%
oem cf hood is $400, pretty much all the other cf hoods are $540.
I don't see why you'd spend $600 cutting up the stock hood.
Old May 21, 2010 | 02:53 AM
ITOzann's Avatar
ITOzann
^$600 must include customizing the hood and paint..! those projects are never cheap at a body shop indeed.. takes lots of time!
Old May 21, 2010 | 04:59 AM
maXmood's Avatar
maXmood
Under Boost!
considering where i live, it's not gonna cost this much..
i'm really better off customizing it for now. saving and ordering one later.
thanks for the ref. tho.
Old May 21, 2010 | 07:53 AM
Lee R's Avatar
Lee R
Here is your template. Good luck!
https://my350z.com/forum/exterior-an...-template.html
Old May 21, 2010 | 08:30 AM
maXmood's Avatar
maXmood
Under Boost!
Originally Posted by Lee R
thanks a bunch.. exactly what i was missing.
Old May 21, 2010 | 08:53 AM
Lee R's Avatar
Lee R
Post pics when done.....
Old May 21, 2010 | 09:19 AM
pablos Z's Avatar
pablos Z
id like to see it in the process of being made
Old May 21, 2010 | 11:23 AM
maXmood's Avatar
maXmood
Under Boost!
will do..
Old May 21, 2010 | 11:25 AM
maXmood's Avatar
maXmood
Under Boost!
unfortunately, i won't have time to DIY or even have the right tools.. so i'll hand it over to the bodyshop.
Old May 21, 2010 | 04:14 PM
adamc's Avatar
adamc
im curious what they will charge to do that on a stock metal hood.. be sure to get back to us on that one.. lol
Old May 25, 2010 | 01:15 AM
maXmood's Avatar
maXmood
Under Boost!
^checked with one bodyshop and they quoted me around $600..
but i'm backing out on this. because of 2 things.
1- won't pass inspection.
2- if i decided to go back to stock and sell it.
so, i'm saving for a TS style hood.
Old May 25, 2010 | 01:55 AM
adamc's Avatar
adamc
you have seen the light.. i didn't want to say too much but was hoping you would not do it.
would be like setting your money on fire.. to roast a marshmallow
in all honesty... finding a good deal on a fiberglass hood would prolly be best bang for buck for ya
Old May 25, 2010 | 02:48 AM
maXmood's Avatar
maXmood
Under Boost!
true that...^
Old Jun 2, 2010 | 10:54 AM
maXmood's Avatar
maXmood
Under Boost!
guys, which hood is this?
Old Jun 2, 2010 | 02:27 PM
pablos Z's Avatar
pablos Z
c west
http://www.z1auto.com/prodmore.asp?m...or&prodid=2065
Old Jun 2, 2010 | 02:57 PM
  #38
maXmood's Avatar
maXmood
Under Boost!
^thank you sir!
***!!!!!!!!!!!!!!!!!!!!!!!!!!!! 1.7k for a hood!!!
Old Jun 3, 2010 | 09:17 PM
  #39
OMERTAITALIA's Avatar
OMERTAITALIA
thats pricey
Old Jun 4, 2010 | 02:18 AM
  #40
maXmood's Avatar
maXmood
Under Boost!
expensive as hell....!!
no one does a replica??
