Drilling into fiberglass bumper question
Old Jun 1, 2010 | 11:41 AM
sancho1596's Avatar
sancho1596
Default Drilling into fiberglass bumper question
Ok guys, I have a nismo v2 vfiber bumper already painted. I want to put on the canards but have to drill holes. Can I do this or will my paint crack? Any suggestions on how to do it if it possible?
Thanks in advance
Old Jun 1, 2010 | 12:12 PM
Yes. Fiberglass is easy to drill. Just remember that it melts so keep drill speed slow.
To prevent cracking tape then drill.
Old Jun 1, 2010 | 01:21 PM
duro78's Avatar
duro78
Do you have a template because they will most likely not be uniform
Old Jun 1, 2010 | 01:49 PM
blue350zed's Avatar
blue350zed
^^^Keep this in mind. Once you figure out where to drill. Cover the area with blue tape and drill through it.
Old Jun 1, 2010 | 02:30 PM
glenns280's Avatar
glenns280
+1 tape an template
Old Jun 1, 2010 | 08:30 PM
sancho1596's Avatar
sancho1596
Thanks so much guys I'll give it a try.
Old Jun 1, 2010 | 09:18 PM
Spork's Avatar
Spork
Or put a tiny glob of paint on each bolt receptacle on the canard, push canard against front bumper to mark where holes should be drilled, and drill away.
Lay a piece of paper over the canard's mounting surface. Poke holes where each bolt hole will be. Lay piece of paper on bumper, and mark through the holes with a sharpie.
Low speed, low pressure. Start with a smaller drill bit.
Justin100
Nov 25, 2021 06:26 AM
sales@czp
Sep 23, 2019 03:30 PM
issyz
Jul 2, 2017 03:04 PM
