Driver side window going down by itself
Old Jun 16, 2010 | 07:53 AM
rodneeking85's Avatar
rodneeking85
Default Driver side window going down by itself
I was just wondering if this has happened to anyone else. My driver side window went down by itself on 2 occasions on the same day. I pulled the window up all the way just using the automatic option rather than just holding the button up and I saw it go all the way up and then I noticed it went down about a ¼ of the way by itself. I thought I was seeing **** and maybe I didn’t pull it up all the way and it happened again later on. Kind of weird to me, this is on a 08 Z that I bought brand new last year. Thanks for any input guys.
Old Jun 16, 2010 | 08:41 AM
Lee R's Avatar
Lee R
Motor might be going out or it might just needs to be cleaned. There are a ton of threads on this so try to search. good luck.
Old Jun 16, 2010 | 09:12 AM
Assume that the warranty is valid. Have the dealer fix it.
Old Jun 16, 2010 | 09:24 AM
Highway Riding's Avatar
Highway Riding
You programmed your window switch accidently to not go all the way up. I did the same thing and have not figured out the fix but pulling the window switch 90% up will raise the window to fully up. Also happens on my Altima. Not just Z's. Call the dealer to find out how to revert back to default and post it up..
Old Jun 16, 2010 | 09:53 AM
AcidJake75's Avatar
AcidJake75
Living in 350Z
theres a reset procedure - thats all you need - if you replace then your going to have to do the reset procedure anyway.
just search for window motor fix and you will find the DIY with pics and how to do the reset action..
DONE
where in TX are you OP? If in the DFW area - bring me a case of beer (DOS XX) and I will hook it up.. doesnt take long at all..
Old Jun 16, 2010 | 11:35 AM
Highway Riding
DONE
searching for reset procedure as we speak but at work and looking at ****
Old Jun 17, 2010 | 12:56 PM
rodneeking85
DONE
I'm In Houston man, maybe we can talk when i go up again. I go up every so often for shows and to hang with friends.
Old Jun 17, 2010 | 08:53 PM
rodneeking85
damn passenger window motor is abou dead... weak.... Gotta go take it in now.
lapham3
Oct 7, 2022 03:15 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
samansharif
Sep 25, 2015 12:31 PM
