ACC multi-tap
Old Jun 17, 2010 | 03:16 PM
revvenue's Avatar
revvenue
Default ACC multi-tap
Hey guys,
Firstly, excuse me if this has been asked before as I did try searching first!!
I want to run a "distribution block" that is powered ONLY when the dome lights are on.. not constant and not ACC (the title says ACC, can't edit it now). I would like it to power footwell lighting, door handle lighting, and a few other items... a total of about 4. And only need power to this distribution at times when the interior light would normally be on (ie the unlock key on the remote, or when opening a door).
I was curious if anyone has found a way of doing this without creating several taps? Would it be ok to tap the dome light switch and run all of these items off of one tap? That sounds too risky to me, and I'd like a clean install as well. If it is okay to do a single tap, where would be the best central place that's not towards the top of the interior?
Thanks in advance!
Old Jun 17, 2010 | 07:24 PM
MDK's Avatar
MDK
Why not use the ACC line on the radio?
Old Jun 17, 2010 | 08:09 PM
Saudi's Avatar
Saudi
i asked a similar question not too long ago... not much advice... although on my hayabusa i used to have, i wired in a fuse block, had 6 slots i believe, but it was constant power, for my garmin, and to charge my cell phone in the trunk and whatever else i wanted to add a fuse into... might be an idea... instead of tapping into the battery, like i did, i was thinking of tapping into the dome circuit...
anybody have any advice?
wayneside
South East
Sep 23, 2015 02:38 AM
two4dee
Sep 18, 2015 09:25 PM
