Need possible ways to raise up the a 350z seats !!
Old Aug 1, 2010 | 05:15 AM
DavesZ#3's Avatar
DavesZ#3
Originally Posted by Z1 Performance
I would not user rubber blocks, or anything remotely maleable to accomplish this - you're asking for trouble IMHO should the car ever be in a serious enough accident. Even a hard rubber block can just shear itself in a serious enough impact, especially if you have a metal bolt running through it.
The rubber block only acts as a spacer, there's no connection between the seat and the rubber block. You buy longer bolts, they pass through the rubber blocks and screw into the original mounting points in the floor. Even if the rubber is sheared, damaged, or somehow separated from the bolt, the bolt is still holding the seat.
Old Aug 1, 2010 | 02:50 PM
Mjfallinup's Avatar
Mjfallinup
i can reach the pedals, just the view isnt good enough, i used to drive a camery so.. the view is totally different between em. wanted to raise it a bit to see the whole view.
Old Aug 1, 2010 | 05:11 PM
Rocknthehawk's Avatar
Rocknthehawk
and the ***** on the side didn't raise it enough?
i'm 5'6" on a good day and sometimes wish the seat would go a little lower.
Old Aug 1, 2010 | 06:34 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
exactly - and that rubber is also now preventing the longer bolt from fully threading into the hole because it's acting as a spacer. Meaning you have a very real chance of that bolt snapping in an accident. If you look at the bolt used to secure the seat base to the floor, you'll see it is fully threaded when torqued properly. Spacing it upwards in something that itself is not solid, and not threaded, seems like an unnecessary risk.
Old Aug 2, 2010 | 03:23 AM
DavesZ#3's Avatar
DavesZ#3
A long bolt still has the same number of threads in contact with the threads of the nuts mounted in the floor. The bolt still has the same force on it in an accident if it's 1", 2" or 3" long.
Old Aug 2, 2010 | 05:36 AM
Z1 Performance
Former Sponsor
But a long bolt through a rubber spacer has an exposed portion that is not threaded through anything..and that unsecured portion is now the weak link/fulcrum of the bolt in the event of an accident. To have the bolt be fully secured, it needs to be fully threaded/engaged
Vigman
Nov 17, 2015 04:34 AM
AngryZ
East Canada
Sep 16, 2015 05:08 PM
issyz
Sep 12, 2015 04:18 PM
