Airbag module placement
Old Jan 25, 2011 | 06:04 PM
jmicaelk's Avatar
jmicaelk
Question Airbag module placement
Hi guys, just wondering if it is the SRS module that sits between the seats ?? and if anyone know how many cable goes to it as it seem it can take 3, but I only have 2 cables going to it.
Old Jan 25, 2011 | 10:36 PM
HyperSprite's Avatar
HyperSprite
Mad Scientist
Default Here's what I know...
You are talking about the airbag in each seat?
I just did a swap from 04 Enthusiast to 08 Nismo seats and the wiring was not the same.
The 04 had two plugs, a small white plug I believe is the seatbelt sensor. This was exactly the same on the 08 seat. The second plug was a large yellow plug that went to the airbag. The car wiring harness had another plug but my seats don't have a plug for them.
The 08 had three plugs, the same small white plug mentioned above I think was for the seatbelt. A small yellow plug that went to the airbag. A third one that I could not track down. It went into the seat foam and I didn't feel like digging it out. It may be the pressure sensor for children, I'm not sure.
The only one that connects to the airbag is the yellow plug.
Since I searched earlier and didn't see anything on it I'll throw in some bonus info here regarding seat airgabs:
As I said, the airbags had different size plugs, I don't know when this changed. I did not want to splice the plugs so I decided to see if I could swap the airbags. Turns out, although the brackets are different, both bags bolt up exactly the same. So an 04 bag fits fine in an 08 and vice versa.
work tip: to work the seat zippers, use a small zip tie and cut them off when your done.
Old Jan 26, 2011 | 07:54 AM
Chebosto's Avatar
Chebosto
the cars after 06 (i think) had weight sensors on the passenger side.. so your extra cable might be for the weight sensor.
as for the thing that sits inbetween the seat, the silver box.. that is the VDC yaw rate sensor (i think thats what you're talking about...)
Old Jan 26, 2011 | 12:04 PM
ashtrojan2008's Avatar
ashtrojan2008
Yes, the silver box with the yellow connectors under the center console between the seats is the srs module. Just disconnect the battery for a few minutes before messing with it. The yaw sensor ppl are mentioning is further forward
Ross
Old Jan 26, 2011 | 12:07 PM
ashtrojan2008
Oh and mine has 3 connectors, with 4 spots. So one is empty.
Old Jan 26, 2011 | 02:00 PM
jmicaelk's Avatar
jmicaelk
Thanks guys, well my harness only have the 2 smaller connectors, but then there is a larger connector in the box that is empty now.
Yaw sensor, sorry but what is that one used for, cuz I couldn't see any cables going to it :|
Old Jan 27, 2011 | 08:19 AM
Chebosto's Avatar
Chebosto
how bout you take some pictures so there is less confusion on what you're trying to describe
Old Feb 8, 2011 | 11:42 PM
chodalak's Avatar
chodalak
aarrgghh
May 1, 2022 11:04 AM
reno56
Interior
17
Nov 20, 2015 05:21 PM
Depravity
Oct 1, 2015 04:49 PM
AngryZ
East Canada
Sep 16, 2015 05:08 PM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
