Reinforce my CF Hatch for a wing.
Old Mar 12, 2011 | 02:35 AM
SIR_pierre's Avatar
SIR_pierre
Default Reinforce my CF Hatch for a wing.
Can somebody please show me pics of how i need to do?
How big braces etc etc
Old Mar 12, 2011 | 05:11 AM
reserved's Avatar
reserved
Working on the same project right now.
Old Mar 12, 2011 | 07:54 AM
terrasmak's Avatar
what wing are you adding?
Old Mar 12, 2011 | 10:00 AM
reserved's Avatar
reserved
I am going with the APR GTC-200. The "recommended" APR wing for our car is the GTC-300, but I was concerned that would be too much weight and stress on the CF hatch.
The 200 will not provide as much downforce, but there is a Gurney flap which can be added if necessary.
Old Mar 12, 2011 | 10:03 AM
reserved's Avatar
reserved
BTW, there is some useful info here
http://forums.bimmerforums.com/forum...d.php?t=938317
My plan is to attempt to add some front splitter support rods like in post #17.
Old Mar 12, 2011 | 10:15 AM
SIR_pierre's Avatar
SIR_pierre
Im going with the Voltex Type 3.
1700mm
Old Mar 12, 2011 | 10:17 AM
SIR_pierre's Avatar
SIR_pierre
But my hatch is to soft anyway even with that kind of rods.
the whole thing flexes with just a little finger pressure
Old Mar 12, 2011 | 12:30 PM
reserved's Avatar
reserved
My hatch is Seibon and that feels pretty flimsy too. I'm going to try to anchor the splitter rods as close to the edge of the trunk as I can. That seems to be where it is most rigid.
I'm also going to use some aluminum plates to reinforce where the actual base of the wing attaches to the trunk.
Old Mar 12, 2011 | 01:16 PM
SIR_pierre's Avatar
SIR_pierre
im think that a plate just dont do it since my whole hatch flexes.. So im thinking of a big X underneath
Old Mar 13, 2011 | 10:10 PM
Fixxxercask's Avatar
Fixxxercask
I'll be switching to a CF hatch after this race season and will probably be doing something like this. Subscribed for results.
Old Mar 14, 2011 | 01:32 AM
Zchan03's Avatar
Zchan03
I went to visit Devari's shop this weekend and they are working on a CF hatch. I think why the other hatches are weak are because they just use a thin layer of fiberglass under their CF. I'll tell Devari about the problems people are having mounting wings on their hatches so that they can make the ones they have stronger.
Old Mar 14, 2011 | 07:02 AM
SIR_pierre's Avatar
SIR_pierre
mine is vacuumed dry carbon.. only a thin layer with nothing between or under.
Old Mar 14, 2011 | 09:48 AM
BoomerZ33's Avatar
BoomerZ33
wish i could add a GT wing. the sloped edge of my Mastergrade prevents me. oh wells it still looks hot.
Old Mar 14, 2011 | 09:49 AM
SIR_pierre's Avatar
SIR_pierre
I have that same hatch... So i have to make custom fotstands.
Old Mar 14, 2011 | 06:57 PM
BoomerZ33's Avatar
BoomerZ33
i thought the same as well. not sure how secure it would be or if it would look ugly. are you in the process of doing it? interested in seeing how yours turns out.
Old Mar 14, 2011 | 09:17 PM
jerryd87's Avatar
jerryd87
if you done care about the huge mounting plate theres always the cwest wing that appears pretty stable i dont have any experience with it though *shrug*
Old Mar 14, 2011 | 11:56 PM
SIR_pierre's Avatar
SIR_pierre
No i havent got my wing yet, Or found someone that can help me with any of the things ive planed on getting made.
Fotstands and the inforcement-part in alu
Old Mar 19, 2011 | 03:24 PM
reserved's Avatar
reserved
Wing installed on CF hatch. It may not be the most esthetic way to do this, but it works!!! This thing is absolutely solid.
On the outside, additional support is provided by splitter support rods. They are adjustable, so the wing angle can still be changed. On the inside, I have 1/4 inch aluminum plates.
Attached Thumbnails Reinforce my CF Hatch for a wing.-mar-20-2011-005.jpg   Reinforce my CF Hatch for a wing.-mar-20-2011-006-copy.jpg   Reinforce my CF Hatch for a wing.-mar-20-2011-008-copy.jpg   Reinforce my CF Hatch for a wing.-mar-20-2011-007-copy.jpg
Old Mar 19, 2011 | 03:58 PM
SIR_pierre's Avatar
SIR_pierre
Finally some pics! Great!
So those two smal pieces is good enough? I dont need a big plate from side to side? Not bad.
How wide is your wing?
Old Mar 19, 2011 | 04:29 PM
terrasmak's Avatar
I figure when i get a GT wing i will just have standoffs welded into the actual trunk and make it so its quick and easy to remove to wing to open the hatch. Something like that will be the best bet.
