Vinyl Ester fiberglass undertray w/ Naca duct, $600 + $
Old Apr 5, 2011 | 08:24 PM
Voboy's Avatar
Voboy
Originally Posted by Chebosto
if you have drawings of your initial design, im sure you could get your 3.
i'd be interested, but i understand fitting a piece like this to the variable exhaust/front/rear bumper combos will be nearly impossible, unless the end user ends up trimming and cutting to fit...and looking it into myself, the mounting solution is 3/4 of the problem. a flat underside is easy.
Not to mention anyone with 350EVO sway bars that loop under the exhaust instead of bend over...
Old Apr 5, 2011 | 08:45 PM
Chebosto's Avatar
Chebosto
Originally Posted by CIANCI USA
I think the best thing for us is to make the undertray fit to the OEM pannels. The end user could modify it as they need with some flat fiberglass extension parts. For the variable height we can mold the fiberglass to contour to the bends.
the OEM panels have varying height underneath... IMHO if you make it fit OE exhaust pieces, OE panels, and let the user figure out how to mount it, the true cost of installing something like on someone that would really use this this would be closer to 1k for the modifications necessary to clear the various exhaust systems the track oriented people already have... im just saying.
here is a large underbody image you can use for initial planning
http://www.z33driver.com/images/bottomofcar/zbottom.jpg
mock up
Old Oct 23, 2011 | 07:14 AM
Voboy's Avatar
Voboy
still a worthwhile project to create bump...
i like your mock up cheston, but i would like to see everything get covered, even the cats and ypipe.. it'd be a little more difficult especially with an aluminum version, but it'd be so much better that way.
Old Oct 29, 2011 | 07:39 PM
misterniceguy's Avatar
misterniceguy
Where is this project at now?
Are there any drawings yet?
Old Oct 29, 2011 | 07:52 PM
Flo-ridaZ33's Avatar
Flo-ridaZ33
Cianci was bought out by someone else so good luck.
Old Oct 30, 2011 | 09:23 AM
misterniceguy
Did this someone else already say they weren't going through with this?
Old Oct 30, 2011 | 09:35 AM
Flo-ridaZ33
mock up
The rear can go all the way up to the rear cross member as my 1st moulding stops at the pumpkin.
Old Oct 30, 2011 | 09:57 AM
bbs350z's Avatar
bbs350z
well fukk, now we really have no fender options
savvy
Mar 6, 2013 09:39 PM
savvy
Feb 19, 2007 10:08 AM
