Padiddle!!!ughh!!
Hey guys..just trying to get an opinion on diagnosis...have a 03 touring...104K...happend 3 times now..drivers headlight will randomly go off...ill go and pull the ignitor goin to the bulb..and sometimes ill wiggle it around and work...tried a 2nd HID bulb...no light...possibilty of the ignitor being bad?anyone else have any issues with a problem like this....just like to know what I need to order to replace it..hate to buy something and not fix it!
thanks!
thanks!
I had a problem like that where every time I took an exit ramp (to the right) off the highway or a hard right turn my drivers side bulb would go off. After turning the headlights off and then back on it was back to normal, but it kept on happening more and more often so I replaced the bulb and never had any more issues.
I am just wondering are you sure that 2nd bulb you tried was good..you had no light..did you try it in the other side? Did you put the oroginal back in after that? was there light on that one? If no you probably need a new ballast, I assume you checked the fuses, relays.
Hope that helps.
Hope that helps.
We'll thursday night the light when out..hasnt worked...unplugged..cleaned...jiggled wires...everything..NOTHING...come out to drive it this evening...and randomly the headlight is working now....this is irritating!!
bapestah
Jan 25, 2009 08:14 AM
