Speedometer cover
Old Aug 4, 2011 | 09:29 AM
350Speed's Avatar
350Speed
Default Speedometer cover
Does anybody know how to remove this cover?
Thanks in advance.
Old Aug 4, 2011 | 09:40 AM
bmccann101's Avatar
bmccann101
do you mean you need instruction PAST the removing of the cluster itself?
Old Aug 4, 2011 | 09:44 AM
350Speed's Avatar
350Speed
I was looking to remove that top cover without touching the cluster. Planning to wrap it in cf.
Old Aug 4, 2011 | 09:57 AM
bmccann101's Avatar
bmccann101
doubt that will happen.
Just buy one of these and be done w it, youl;l like it better anyway.
http://cgi.ebay.com/ebaymotors/Nissa...Q5fAccessories
otherwise, you yank on the plastic under the column and pull it down, leaving the hood pop fastened as its a total ***** to replace it... theres 4 screws holding the plastic under your column itself, then theres 4 simple bolts to take the cluster off. you could then take that cluster apart..
but why would you even try? mask it, spread some primer 94 on the areas you want to wrap, wrap the dinoc over the whole mess, and trim to the edges of the mask underneath w a razor.. pell off your remaining masking tape....and hope to God it sticks in the heat of the sun.... good luck.
See why the cover you can buy is a no brainer?
Old Aug 4, 2011 | 10:11 AM
350Speed's Avatar
350Speed
I got your point, but just want to wrap it to match the waterfall center piece.
Old Aug 4, 2011 | 12:21 PM
bmccann101's Avatar
bmccann101
i hear ya, well there ya go, yer step by step.
you can do it all while seated, no need to get under the dash until its time to put it back together.
Old Aug 4, 2011 | 01:26 PM
redman333's Avatar
redman333
hammer
Old Aug 4, 2011 | 02:00 PM
350Speed's Avatar
350Speed
Originally Posted by redman333
hammer
I hope you didn't do that to your Z.
Old Aug 4, 2011 | 02:35 PM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
hammer
Everyone knows that the hammer is the best tool for any job.
Old Aug 4, 2011 | 02:44 PM
redman333's Avatar
redman333
I promise if you hit it just right it'll come right off no problem.
Old Aug 4, 2011 | 02:57 PM
JCITY's Avatar
JCITY
Default Cf molded piece
Thanks in advance.
May be better to just buy a CF Cover for the cowl.
You would not have to worry about the heat.
Have one on my Z...
Z-STORE/MOTORSPORTS SELLS E'M
Old Aug 4, 2011 | 04:21 PM
CleanFairladyZ's Avatar
CleanFairladyZ
you have wayyy too many miles on your car
Old Aug 13, 2011 | 10:35 AM
lbz's Avatar
lbz
Click here, scroll down and print pages 15 - 19. That should give you the info you need.
3vilbunny
Jul 18, 2017 05:10 PM
ablaine
Nov 29, 2016 10:13 AM
2ndchanceZ
Oct 26, 2015 08:03 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
