Center gauge question.
Old Aug 8, 2011 | 11:29 AM
Daron's Avatar
Daron
Default Center gauge question.
Can you swap out the two gauges(oil and volt) with aftermarket ones and still leave the data gauge stock?
Old Aug 8, 2011 | 12:47 PM
kcalvano's Avatar
kcalvano
it would be a ***** since the data is connected to the same circuit board. you would have to remove the data lcd and extend the leads. I tried it and broke a couple of the pins and gave up and installed an obdII gauge
Old Aug 8, 2011 | 05:17 PM
redman333's Avatar
redman333
Can be done but no easily. Depends on how much time you want to invest in the project. I thought about doing this also but decided not to.
Old Aug 8, 2011 | 06:05 PM
midz350's Avatar
midz350
Yes, I did it:
https://my350z.com/forum/forced-indu...n-be-done.html
Old Aug 8, 2011 | 06:11 PM
Z1NONLY's Avatar
Z1NONLY
I replaced my volt meter with the display from my STi-R radar detector. (then set the display to show vehicle voltage.
Here's a pick I took when I repainted my dash. It shows a little of what you are dealing with.
The volt meter had it's own PCB, so I wasn't too worried about messing up the data gauge PCB.
It looks as though you could have some issues with space for the center gauge. I don't know the dimensions of the gauges you want to use, but the STi-R display was only ~.5" deep and fit easily between the face of the existing gauge and the plastic cover.
To ensure, I didn't "confuse the stock data gauge, I left the stock voltmeter connected and just cut the needle off. -Probably wasn't necessary.
sales@czp
Sep 23, 2019 03:30 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
