06+ headlight repair
Old Aug 11, 2011 | 08:28 PM
TurboTom's Avatar
TurboTom
Default 06+ headlight repair
I was involved in a hit and run last week and this is what happened to my headlights
I've searched and found some thread where people say you can buy just the housing but havn't actually found someone who had bought it
My question..can this problem be fixed without buying new headlights??
Is there a place where I can buy OEM housing (all lights work fine just cracked housing)
Thanks for any help
UPDATE:
Lights are done and on the car...came out great and turns heads everywhere. Every time I pull into a parking lot I turn my long lights off leaving the ccfl, corner, and led lights on and people just stop and stare (GREAT FEELING).
Heres a quick pic I shot. I'll throw a vid up soon.
Special thanks to flipper z for making them
Old Aug 12, 2011 | 03:38 AM
The_Marne's Avatar
The_Marne
Insurance isn't covering that? Would suck to pay 600 bucks for one '06 headlight.
What's your deductible?
Old Aug 12, 2011 | 04:22 AM
TurboTom's Avatar
TurboTom
All I got is liability..insurance isn't gonna do s***
Old Aug 12, 2011 | 04:59 AM
The_Marne's Avatar
The_Marne
Looks like prices came down. Says its 06-09 but doesn't say exactly if its bi xenon.
http://www.go-part.com/0609-nissan-3...r-p-41933.html
Old Aug 12, 2011 | 05:20 AM
BoomerZ33's Avatar
BoomerZ33
sucks to hear op. a friend of mine was involved in a far worse hit and run last week as well.
it's hard to assess the amount of damage from your pic. its also a tricky and delicate process to separate the cover from the rest of the housing if you were to repair yourself. i would just search for and buy a replacement.
Old Aug 12, 2011 | 05:23 AM
F34RL355's Avatar
F34RL355
did the guy reverse into you? i have a whole light assembly but i cant remember what side it is i think its driver though i will check tonight for u.
sorry just noticed my assembly is from 04
Old Aug 12, 2011 | 05:50 AM
cheshirecat79's Avatar
cheshirecat79
Are those cracks or is the plastic just "smudged"? I can't really tell. If they aren't cracked, a heavy sanding job may pull the damage out of the plastic.
Old Aug 12, 2011 | 06:43 AM
The_Marne's Avatar
The_Marne
Definitely a giant crack right up the center. Sandjob will be a no-go.
Old Aug 12, 2011 | 06:54 AM
ATL_Red_G35's Avatar
ATL_Red_G35
can u just buy the ebay light and swap out the lens cover if that's the only thing wrong with the HL?
Old Aug 12, 2011 | 07:13 AM
TurboTom's Avatar
TurboTom
thats what im trying to figure out..dont see a point in buying new headlights it they work...they're just cracked to hell
Old Aug 12, 2011 | 09:47 AM
ZJoe's Avatar
ZJoe
Yes, an Ebay headlight will work. When my 06-08 lights were being customized the inside of one of the lenses was wiped due to some residue and it screwed up the internal coating.
An ebay headlight purchase fixed the issue and it was the 03-05 lights too. Just take off the lens cover (see the customizing headlights DIY) and put the new one on from the Ebay light. Works perfect and shouldn't cost more than a couple hundred bucks compared to the cost of a new 06 light. Keep the second one as an extra in case you need to do the same for the other side. Done and done.
Old Oct 2, 2011 | 10:46 AM
kaizenro1's Avatar
kaizenro1
Are Ebay lights any good?
Old Oct 3, 2011 | 01:39 AM
d3vil's Avatar
d3vil
yeah just buy an old 03-05 lights with a nice housing
DIY remove and replace to your 06 lights, its the smartest and cheapest way to go
Old Oct 3, 2011 | 05:46 PM
TurboTom's Avatar
TurboTom
The front cover from an 03 headlights will fit on the newer style light yes, but the back part (the piece the projector is mounted to) won't work. Since both mine were cracked I bought the eBay housing for $300 and yes it looks identical
Old Oct 3, 2011 | 05:48 PM
TurboTom's Avatar
TurboTom
Also decided to modify them while I was replacing them ...with a lot of help from. flipper z ..pics up soon
Old Oct 31, 2011 | 12:26 AM
FliPPER_Z's Avatar
FliPPER_Z
From this...
To this..
http://www.youtube.com/watch?v=_ZwojNW-iC8
Almost done Tom!
Old Oct 31, 2011 | 01:19 PM
TurboTom's Avatar
TurboTom
I'm speechless
Old Feb 15, 2012 | 09:16 PM
TurboTom's Avatar
TurboTom
Old Feb 15, 2012 | 10:08 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
I want to see these in person sometime. You go out to any of the meets or events around Chicago?
Old Feb 15, 2012 | 10:10 PM
hyuk28719's Avatar
hyuk28719
I recently swaped lenses on my 06 headlights due to stress cracks and condensation. Bought a set of ebay light housing (03-05) for $185, Oxy Butyl for $25 and successfuly finished the job.
