abs plastic sheets
Old Sep 21, 2011 | 08:18 PM
aasorah's Avatar
aasorah
Default abs plastic sheets
I have a plan to make one of the homemade front splitters such as the arc one only abs plastic 3/8ths thickness and cannot find any in my small town. Tried builders source, 2 plastics factorys and no luck.
Old Sep 21, 2011 | 09:00 PM
Anomaly's Avatar
Anomaly
McMaster Carr is a great shop to order from:
http://www.mcmaster.com/#plastics/=e61jff
Or mail order from Amazon?
http://www.amazon.com/s?ie=UTF8&keyw...k%3AABS&page=1
Old Sep 21, 2011 | 09:11 PM
Chebosto's Avatar
Chebosto
abs will flex and sag over time. you'll need something reinforced. unless you're only making a small piece
Old Sep 22, 2011 | 08:45 AM
aasorah's Avatar
aasorah
Awesome. I had run up on amazon but there maximum size is 1 foot by 2 foot from what I have found. Ill Check out McMaster and I figured making one would be fun and easy to replace when this splitter gets scraped up on the underside. Instead of scraping up a 300 dollar apr splitter. I seen where people use plywood (I laughed out loud until I gave it a chance and looked it up to see.) But ABS plastic just seems all around better to me.
Old Sep 23, 2011 | 08:35 AM
Chebosto's Avatar
Chebosto
have u seen my post on Alumilite?
aluminum sandwiched plastic honeycomb. my undertray is made of this stuff.. easy to cut as well...
http://www.rhino-graphics.com/signs/alumilite.html
you can purchase this in large sheets and its very strong per weight. imho better than ABS plastic.. plus it won't melt since it's underneath the engine/oil pan where there will be significant heat generated.
check it out.
aarrgghh
May 1, 2022 11:04 AM
HoneyBadgerRy
Sep 21, 2015 03:25 PM
