Mounting sideskirts
Aftermarket sideskirts, how and what are people using to mount them? The bottem, rocker panel area is easy, but the door jam area is what i'm concerned with. So far ive thought of using the OEM style pop clips, rivnuts, Countersunk Plusnuts and many other versions. What is everyone else using?
check out my diy thread broskee:
https://my350z.com/forum/body-interi...f-install.html
I used sheet metal screws, no rust til this day
Do you really need to special tool to install the rivnuts?
Very tempting also
They may have to come off from time to time. I hope they clear my trailer when i pick it up. I wish it was easy to install them with 1/4 turn fastners, that would be my prefured method.
I'm about to go through this as well and am a little on the fence about the side skirts. I don't mind the bumpers at all, they are easy... but the side skirts present some problems just because they don't use the same factory mounting tabs like stock. This thread helped easy my worries a bit, though I may still consider paying to have them installed if I'm sure the result will be more professional that I could do on my own.
That's a good idea. It doesn't have the strong wind pushing it in a direction that should compromise the integrity of the adhesive given the other mounting points are done properly.
