Carbon fiber hatch
Old Nov 10, 2011 | 10:09 PM
brian2193's Avatar
brian2193
Default Carbon fiber hatch
I was thinking about replacing my stock hatch with a carbon fiber one but i was wondering what happens to the rear defrosters and the rear window wiper? can you still connect them somehow or are they gone for good with a carbon fiber hatch?
Old Nov 10, 2011 | 10:16 PM
Barnabas's Avatar
Barnabas
National Z Club President
you "could" connect them.... but why? Do you really look out that back window enough to need a wiper and defrost?
BTW you would have to drill a hole in order to install the wiper +motor. Plus the whole reason for CF hatch is to save weight. That motor is HEAVY.
Old Nov 11, 2011 | 04:33 AM
Jenkins651's Avatar
Jenkins651
Many people do the wiper delete just for this reason. You may miss the defrost in the winter if it is your daily driver, but I doubt you will ever miss the wiper. If it bothers you that much just put rainx on it every month
Old Nov 11, 2011 | 05:07 AM
Bigchef66's Avatar
Bigchef66
depending on which carbon trunk you use the provision to reuse the wiper assy is catered for. i.e VIS have holes bored, mastergrade if you can find one doesn't, rear defrost is just simple routing of oem harness and retention of oem glass...
Hope this answers your question
Old Nov 11, 2011 | 05:38 AM
BoomerZ33's Avatar
BoomerZ33
yes you can retain the defrosters when you swap to a CF hatch. don't worry about the rear wiper. the Z looks better without it.
Old Nov 11, 2011 | 07:57 AM
Earmuffs's Avatar
Earmuffs
Wiper delete
+1
This
I would add if you are driving the Z in the snow you need to just spend the money from that hatch on a winter car.
Old Nov 11, 2011 | 11:48 AM
Chebosto's Avatar
Chebosto
the defroster in the window would need to be grounded thru a wire to chassis (near the hinge and run the wire up along the sides) and you should be ok.
Old Nov 11, 2011 | 12:50 PM
bbs350z's Avatar
bbs350z
skip the wiper and retain your oem glass. for true weigh savings id suggest lexan/plexiglass, but it scratches easy and the weigh savings are minimal for street use w/ full interior, stereo etc
Old Nov 19, 2011 | 10:59 AM
brian2193's Avatar
brian2193
thanks everyone this really helped out
Old Nov 19, 2011 | 12:13 PM
lgear080's Avatar
lgear080
Any thoughts on a full rear window delete on a cf hatch painted
To match car?
Old Nov 19, 2011 | 03:29 PM
Jenkins651's Avatar
Jenkins651
I'm not sure that is even legal?...
Old Nov 19, 2011 | 07:10 PM
Chebosto's Avatar
Chebosto
why not? if you got at least one side mirror, then you can legally have no rear window.. think of what utility vans or what Pedobear drives.. no rear windows...
Old Nov 19, 2011 | 07:20 PM
lgear080's Avatar
lgear080
I was gonna add a rear view camera later...
I just bought a vis hatch cheap and am planning this.
Old Nov 20, 2011 | 02:49 PM
ambushphoto's Avatar
ambushphoto
What are you going to use to get rid of the rear window? CF or FG panel then smooth out the seams? Doing lexan would be approx. same weight. If you were to paint it to match it would look pretty good. Paint chips off of it pretty easy if it isn't painted properly though.
Driving won't be too bad since you can barely see out of the rear window anyways. :P
Old Nov 20, 2011 | 04:48 PM
lgear080's Avatar
lgear080
whatever is the lightest... prob fiberglass.
Old Nov 20, 2011 | 06:08 PM
Chebosto's Avatar
Chebosto
unless you use woven FRP and bag it, it'll prob weigh more than the thin 0.25" lexan.. 0.25" Lexan is ~ 1.56 lbs/ft^2
Old Nov 20, 2011 | 08:42 PM
terrasmak's Avatar
Actually most state laws require you to have driver and pass side mirrors if there is no rear window. Cali especially.
Old Nov 20, 2011 | 09:31 PM
lgear080's Avatar
lgear080
I'm into the hatch for nothing and just wanted the quickest solution.
I felt like we'd have to glass it either way... whatya think?
Old Nov 22, 2011 | 11:05 AM
Chebosto's Avatar
Chebosto
actually not too bad...
Old Nov 22, 2011 | 11:40 AM
lgear080's Avatar
lgear080
I was thinking completely shaved
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
