Nismo Ti Shifter + Finisher noisy
Old Nov 11, 2011 | 04:46 AM
starbuck's Avatar
starbuck
Default Nismo Ti Shifter + Finisher noisy
I bought a Nismo Ti shift **** a few months ago and recently purchased and installed a metal finisher. It looks great but the problem is when I get above 4,000 RPM or so the finisher starts to rub against the shifter and rattle profusely.
I know a lot of people have the same setup that I have, how did you guys fix this problem?
Thanks
Old Nov 11, 2011 | 09:01 AM
ReelBigAndy's Avatar
ReelBigAndy
I have the nismo gt titanium **** and custom finisher (part of a door magnetic door stop kit from home depot, long story) and I used a thin rubber gasket (~1mm thick, also from home depot in the misc. hardware drawers) that had the right inner and outer diameter.
Old Nov 11, 2011 | 10:16 AM
starbuck's Avatar
starbuck
I'll try that, thanks
Old Nov 12, 2011 | 05:45 AM
starbuck's Avatar
starbuck
Well I went to Lowe's and they didn't have a rubber gasket that even came close to the size I needed. =/
Old Nov 14, 2011 | 06:53 AM
ReelBigAndy
Mine basically looks like a quarter with a 1/4" or so diameter hole through the middle. You can also try putting some sort of rubber/foam spacer(s) underneath the shift boot collar. this will push the boot collar up towards the finisher, and the finsher up against the ****. Sandwiching the finisher tighter should reduce the chatter.
Or just get a rubber finisher.
Old Nov 14, 2011 | 08:45 AM
starbuck's Avatar
starbuck
I ended up getting a neoprene spacer that I trimmed and it works just fine.
$0.89 at Home Depot.
350Z_Al
Oct 29, 2020 07:44 PM
sales@czp
Sep 23, 2019 03:30 PM
nanotech
Oct 2, 2015 05:02 AM
