build full under tray and diffuser
Old Feb 16, 2012 | 10:47 AM
  #41
08NismoZ's Avatar
08NismoZ
Here is another thread with an RX7 that a guy is trying to figure out a full undertray also. He posted some good diagrams that I was trying to explain but pictures are always beneficial haha.
http://www.rx7club.com/showthread.php?t=873466
Old Feb 16, 2012 | 11:50 AM
  #42
350z-900whp's Avatar
350z-900whp
going to read these threads. its weekend now hear until saturday so i have time to adjust the design talk more about ideas
Old Feb 17, 2012 | 11:08 AM
  #43
350z-900whp
some diffuser ideas
Attached Thumbnails build full under tray and diffuser-26.jpg   build full under tray and diffuser-23.jpg   build full under tray and diffuser-24.jpg   build full under tray and diffuser-25.jpg   build full under tray and diffuser-11.jpg
Old Feb 17, 2012 | 11:45 AM
  #44
08NismoZ's Avatar
08NismoZ
Looks pretty good so far. Do you have a track nearby to run lap times and compare different designs? If you could tie the undertray in behind the tire so there's no holes under the car except vents. Have you though venting your rear bumper also to allow cooling for the diff?
Old Feb 17, 2012 | 01:29 PM
  #45
350z-900whp
the closest track is 4 hr drive.
that what i though about is 2 design
1-similar to pic 4 all mount point are under rear bumper with big vent in the middle like F360 so no diffuser sticking out side the car.
2-similar to pic 2, similar to varis diffuser for 350z. with a small gap between diffuser and rear bumper . or cut space in rear bumper between 2 tips
i would like to see if their is a top speed gain and gain stability at high speed as i would really like to see how its going to feel past 140mph. my top speed record in my z is 184 mph
Old Feb 17, 2012 | 04:23 PM
  #46
xjuddx's Avatar
xjuddx
I watched a documentary on race car design a while ago and it got me interested in doing something like this. I did a bit of research then decided to focus on other projects first. Glad to see somebody taking this on.
Would there be a benefit to using aluminum over carbon or carbon/Kevlar in the front and rear sections that will need more molding? I would think it would be easier to make a mold for the pieces and use carbon. Maybe I just don't like working with sheet metal.
the 7 degree info is very good to know. I had been aware of the need for the bottom not come down but didn't know exactly how.
Old Feb 18, 2012 | 02:19 AM
  #47
350z-900whp
this is my hand built diffuser . it hard to keep every thing straight with a duct tape but i tried to do my best, just to get an idea how it might look. the pice in the middle between the to fins it going to be a vent behind LSD to ward the end of diffuser molded with the under tray. also straight pice between to fins came to me from F1 diffuser
for the front i thought of making lip rather than a flat pice of aluminum sticking out . i know its nothing but just to through out some ideas
your thought please
Attached Thumbnails build full under tray and diffuser-al-shuwaikh-industrial-3-20120218-00467.jpg   build full under tray and diffuser-al-shuwaikh-industrial-3-20120218-00468.jpg   build full under tray and diffuser-al-shuwaikh-industrial-3-20120218-00472.jpg   build full under tray and diffuser-img-20120218-00471.jpg   build full under tray and diffuser-diffuser.jpg
Old Feb 18, 2012 | 03:15 AM
  #48
KingBaby's Avatar
KingBaby
Hardest Setting
looks like it's to low! The blades are gonna touch the grown when the car is under load. Depends on your suspension, but still you may need to trim it some. Other than that the idea is sound.
What gauge material are you gonna use?
Old Feb 18, 2012 | 03:16 AM
  #49
350z-900whp
i chose aluminum for 2 reasons first no one her in kuwait do this kind of molds . second aluminum can take beating specially with speed bumps her
Old Feb 18, 2012 | 03:18 AM
  #50
350z-900whp
sure the fins going to be much smaller i was just too laze to recut them
same as viper under tray
Old Feb 18, 2012 | 06:59 AM
  #51
08NismoZ's Avatar
08NismoZ
Yeah looks like a good start. +1 on the vortex generators being a lot smaller. I noticed you plugged up the hole by the right side tire, just don't forget about the hole behind the left side rear tire.
Old Feb 19, 2012 | 10:08 AM
  #52
350z-900whp
I want to know what is the material type or code of viper undertray ?
Thing is garage qoute me 4 times more money for raw material than intial project start. I want to clear my head before contunie the project
Old Feb 19, 2012 | 12:53 PM
  #53
08NismoZ's Avatar
08NismoZ
On the GTR its 3 pieces and the rear piece is dry carbon fiber, the other 2 pieces are just a hard plastic. What about just making yours out of sheet metal or a thin aluminum, and then shop around to see if anyone can use your pieces to make a mold either plastic or carbon fiber?
Old Feb 19, 2012 | 01:33 PM
  #54
350z-900whp
thats what I'm looking to work with either aluminum or any other type of metal thats light and durable.
the tech as we started he said carbon-aluminum what we are going to use and he claim each pice cost something close to 223 dollars ? then i when went around some aluminum shops to verify no one know this type of material or even deals with and their prices are 55 dollars for 1 sheet thats huge difference which makes me question the if the tech is quoting me way too much for materials to gain maximum profit of me
i need to know is what type of material dose the dodge viper use for its under tray ? because the tech side its same material , so i can by the material my self and continue my project
Old Feb 19, 2012 | 04:17 PM
  #55
GreenGoblin's Avatar
GreenGoblin
Glad to see the project progressing. Just use a regular sheet alum.
Old Feb 19, 2012 | 04:30 PM
  #56
Stock2Autocrozz's Avatar
Stock2Autocrozz
nice, sub'd
Old Feb 19, 2012 | 09:06 PM
  #57
08NismoZ's Avatar
08NismoZ
Yeah man just use some thin aluminum to start off. You'll want to make this first attempt cheaply so you can drive with it on and fine tune it some more after track testing.
Old Feb 20, 2012 | 10:53 AM
  #58
Chebosto's Avatar
Chebosto
use corrugated aluminum with plastic honeycomb.
strong. light. relatively cheap. same stuff i made my front undertray from.
http://www.laminatorsinc.com/sign-pa...ucts/alumalite
Old Feb 20, 2012 | 12:31 PM
  #59
ocdz's Avatar
ocdz
Here in the states you can pick up 1/4 inch abs plastic for around $125 per 4x8. If I were working on the same project I'd either use that or stuff in above post.
Old Feb 20, 2012 | 06:52 PM
  #60
projectsupra's Avatar
projectsupra
The viper rear diffuser is a molded carbon fiber plate with aluminum fins, not a carbon fiber/ aluminum sandwich.
The under panels are just aluminum.
