Help with Rear Turn Signals
Old Dec 27, 2012 | 12:40 PM
BMGz33's Avatar
BMGz33
Default Help with Rear Turn Signals
Ok well I tried searching around but had no luck... Just wanted to know what secures the rear turn signals as one of mine came loose and it bothers me seeing it like that...
Thanks for any help
Old Dec 27, 2012 | 12:56 PM
SQuaLZ's Avatar
SQuaLZ
Are you referring to the bulb or the assembly?
Old Dec 27, 2012 | 01:05 PM
redline06's Avatar
redline06
there are two screws for each turn signal if i remember correctly, youll need to remove the rear bumper to see them
Old Dec 27, 2012 | 02:22 PM
BMGz33's Avatar
BMGz33
Thank You... I will get on this tomorrow after the wind calms down over here
Old Dec 28, 2012 | 06:36 AM
redline06's Avatar
redline06
be careful when removing the rear bumper, there is a clip on each side where the bumper meets the quarter panel right underneath the tail light. dont just pull on it hoping itll come off, you need to turn the clip 90 degrees, i used a very very small ratchet with an 8mm socket if i remember correctly, may have been a 7mm though lol, its a pain in the *** but youll get it.
samansharif
Sep 25, 2015 12:31 PM
