Crash bar hardware?
Old Mar 1, 2013 | 08:49 PM
zach711f's Avatar
zach711f
Default Crash bar hardware?
So I've been running around with a crash bar for about 2 years because the inter cooler is in the way...finally got around to making it fit. Guess what. I lost the hardware...does anyone know the size hardware? Should be 2 bolts and two nuts for each side.
Old Mar 1, 2013 | 09:08 PM
bealljk's Avatar
bealljk
cool thing with nissan there are like 6 or 8 different sizes of bolts and nuts…
with that being said…you are mounting your aluminum bumper member to a crash cushion like block that mounts directly to the frame? The 4 bolts that hold the crash-cushion-block to the frame are the same size of bolts and nuts that fix the aluminum bumper member to those crash-cushion blocks…
If for some reason you want my old hardware I will send them to you…no charge…I'm going structural bumper-less on my build…and have all that **** laying around...
Old Mar 2, 2013 | 05:16 AM
zach711f's Avatar
zach711f
Sweet thanks man! By the wayi know rhat this thing wont provide any real protection espically since i cut it all up. Its just a temp thing till i getmy bash bar made.
Old Mar 2, 2013 | 05:45 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
M8 x 1.25
Bolts are probably in the range of 15-25mm
Old Mar 2, 2013 | 08:35 AM
bealljk's Avatar
bealljk
In my weight reduction days…it took about 10lbs off the car...
The front has since been salvaged with my recent turbo build…If you want these OEM bolts/nuts PM me your address…it might just be easier to get them locally...
Old Mar 2, 2013 | 11:37 AM
zach711f's Avatar
zach711f
Jesuse christ man!
Rowlett
Misc.
Oct 2, 2015 10:38 AM
nanotech
Oct 2, 2015 05:02 AM
samansharif
Sep 25, 2015 12:31 PM
