Short Shifter?
Old Mar 6, 2013 | 09:21 AM
Jakoby's Avatar
Jakoby
Default Short Shifter?
i really want to get a short shifter.....any suggestions? i wanna stay around 100-150$ but if there is one that is alot better for 200 ill look into it.
thanks, jake
Old Mar 6, 2013 | 09:27 AM
morphiusrt's Avatar
morphiusrt
There aren't many options from what i've seen.
B&M, Nismo and TWM pretty much.
But I'm interested to see others opinions.
Old Mar 6, 2013 | 09:31 AM
faiz23's Avatar
faiz23
FEZZZZZZ
Nissan already put one in your car for free and you should learn to use it. Maybe look into a weighted shift **** that can be adjusted to the right height. You need a combination of leverage/height along with weight to be able to throw the shifter into each gear. You can try a TWM short shifter but you will greatly benefit from a weighted shift ****. Check out the TWM M1 abrams since that is the lowest height and still weighs almost 1 lb.
http://www.twmperformance.com/shorts...rtshifters.htm
http://www.twmshiftknobs.com/shiftkn...hiftknobs.html
For all you noobs out there...READ THE FARKING OWNERS MANUAL....geez
http://www.nicoclub.com/FSM/G35/
http://www.courtesyparts.com/pdf/2005-Nissan-350Z.pdf
http://www.courtesyparts.com/owners-manuals.php
MANUAL TRANSMISSION Shifting
To change gears, or when upshifting or downshifting,
fully depress the clutch pedal, shift into
the appropriate gear then slowly and smoothly
release the clutch.
This vehicle is equipped with a short throw
shifter manual transmission
. To ensure smooth
gear changes, fully depress the clutch pedal
before operating the shift lever. If the clutch
pedal is not fully depressed before the transmission
is shifted, a gear noise may be heard.
Transmission damage could occur
Old Mar 6, 2013 | 09:48 AM
terrasmak's Avatar
^^^ +1 , no need on this car. Cool for a Civic or something
Old Mar 6, 2013 | 10:31 AM
SQuaLZ's Avatar
SQuaLZ
The 350Z's stock shifter is perfect. I would never put a short shifter on it.
Old Mar 6, 2013 | 10:32 AM
SQuaLZ's Avatar
SQuaLZ
I had a short shifter on my Civic
Old Mar 6, 2013 | 10:35 AM
DrGOLD's Avatar
DrGOLD
there is the AMS short shifter
Old Mar 6, 2013 | 10:53 AM
350zjason350z's Avatar
350zjason350z
Know it all
When I first got my z I bought the b and m short shifter for my car and while installing it, little did I know the person who owned the car before me already installed the same shifter ... Fail
Old Mar 7, 2013 | 03:20 AM
morphiusrt's Avatar
morphiusrt
Did that on my SRT4. But they only had a mopar (40% shorter). I put in a maddog (80% shorter). I loved the nice tight feel of a short shift.
Nissan also put the clutch pedal release where they did, so don't go talking about Nissan like they only make perfection.
Old Mar 7, 2013 | 09:58 PM
Jakoby's Avatar
Jakoby
okk i test drve a Z with one and i really liked it, i think i might ust buy one and put it in and try it its not that much and easy to install. but thanks for the input.
Old Mar 8, 2013 | 06:23 AM
SQuaLZ's Avatar
SQuaLZ
The clutch pedal is made for hard driving or racing.
I admit it sometimes sucks on the street, but when you push the car hard and are shifting hard, I think it feels perfect.
Old May 15, 2013 | 01:23 PM
goracerx's Avatar
goracerx
I have TWM lever and ****. It's only about 1/3 shorter throw. I does not improve the notchy feel. Get the RJM pedal kit for that instead. It does seem to lock in gear better, but that could be from the weighted ****. I have the phantom hybrid which only gets warm with the top down on 102 day. I did have to raise it for a better pendulum effect. I can't compare to Nismo or Stillen as I haven't used them.
apex locator
Oct 6, 2015 05:58 PM
Depravity
Oct 1, 2015 04:49 PM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
