370z Steering wheel fits!!!!
Old Jul 16, 2013 | 03:40 PM
  #41
KingBaby's Avatar
KingBaby
Hardest Setting
Originally Posted by Angel55
Yup! My pictures prove it.
Which pictures? You can relax your defenses...those pictures prove nothing
Old Jul 17, 2013 | 06:39 AM
  #42
iideadeyeii's Avatar
iideadeyeii
Cruise Control?
nvm don't care. Airbag/steering wheel is like $700+. Not worth it unless you crashed and had to replace stock airbag
Old Jul 30, 2013 | 05:41 PM
  #43
Angel55's Avatar
Angel55
Originally Posted by iideadeyeii
Cruise Control?
Unfortunately, the cruise control does NOT work due to the wiring locations that are placed at different locations in the connector.
The first picture shows how the original 350z wire looks like compare to the 370z wires.
The only wire that matches the 08 wiring components is the brown wire, which deals with the audio controls. If I can manage to change the 370z wiring to matches the 350z wiring then the cruise control may work. The problem is getting the wires out is the issue. I have to find the right size terminal pin removal, which will take time....possibly longer since im busy with work and school.
Old Jul 31, 2013 | 06:33 AM
  #44
abarclay's Avatar
abarclay
Props for even trying this OP & thanks for updates!
Old Jul 31, 2013 | 06:45 AM
  #45
Aust350z's Avatar
Aust350z
Someone link to a wiring schematic of the 370z. I'll work out where the pins need to be swapped to. Multi-continent, forum-wide mod project begins
Old Jul 31, 2013 | 12:19 PM
  #46
Angel55's Avatar
Angel55
Thanks!
That not necessary. I was searching for the correct tools to remove the pin wires because a typical paper clip was not helpful until I found this thread.
http://www.clubfrontier.org/forums/f...0/index11.html
Frontiers has a similar wire configuration to the 350z because based on what I am experiencing with the controls is similar to what the frontier expert has experienced.
According to Ino8, the red and black wire are for the Cruise Control switches. The wire colors for the Audio switches are white, blue, and brown. And the green wire is for the horn.
Here are the buttons on the 370z steering wheel that work and not work:
Buttons that work:
-Mode
-Track Next
-Volume Up (answer phone button)
-Horn (Decrease Volume Button)
Buttons that do NOT work:
-All Cruise
-Volume Down
-Track Repeat
On the 370z steering wheel, the green wire is connected to the audio section where wire blue is suppose to be and as a result the volume decrease button becomes the horn noise. One time a crazy driver almost hit me due to his wreckless driving habits and I tried to hit the horn but realized that I pressed the wrong button, which is the horn button in my case due to the different locations of the wires in the connector. The volume decrease button is considered as the horn.
Right now I am waiting for the special tools to remove the pin wires to arrive. Once the tools arrive, I'll finish the problem I let you know how it goes.
Old Jul 31, 2013 | 01:14 PM
  #47
David_2613's Avatar
David_2613
Buttons that work:
-Mode
-Track Next
goes.
That made me laugh out loud, I dunno, just a funny visualization.
Great job OP! Props to you.
I swapped a Skyline steering wheel into my 240sx with some modifications.
Looking forward to seeing the final results.
Old Aug 2, 2013 | 04:25 PM
  #48
Angel55's Avatar
Angel55
**Update
Everything WORKS!
Once the tools came, I immediately made the changes to the wire pins.
Here are the wire comparisons.
As the picture shows, the cruise system now works and the Horn noise is now activated in the middle of the airbag.
Old Aug 2, 2013 | 05:16 PM
  #49
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Awesome. How did ya do it
Old Oct 10, 2013 | 10:02 PM
  #50
ttknf's Avatar
ttknf
bump.
Can we get a pin-out diagram? Is the non-bluetooth steering wheel switch set required to make it work? I'm seriously interested in doing this with the new 2014 Nismo Z steering wheel.
Old Oct 11, 2013 | 07:32 AM
  #51
Angel55's Avatar
Angel55
Originally Posted by ttknf
bump.
No the non-bluetooth steering wheel is not required. I have both and they work fine. The blue tooth would require the wires to be at different locations due to the addition of the bluetooth buttons. I just used the bluetooth for the time being until I can finish it completely. I do not have the time to finish it but I have some pictures to show the wire comparisons.
The left wire is what the 370z originally looks like while the one on the right is the modifications I made to make it work.
Old Oct 12, 2013 | 09:06 PM
  #52
KingBaby's Avatar
KingBaby
Hardest Setting
It's definitely a nice wheel...
Old Oct 14, 2013 | 06:05 AM
  #53
Angel55's Avatar
Angel55
Thats why i bought it. It feels more sporty and more smoother when driving.
Old Oct 14, 2013 | 06:39 AM
  #54
redline06's Avatar
redline06
I want this! Good thing I have a Base so all I really need is a functioning Airbag, oh and the horn because I use **** quite often lol
Old Feb 16, 2014 | 08:07 AM
  #55
2004Black350z
Exhaust Whore
Has anyone else mastered this? All I really care for is horn and cruise
Old Feb 16, 2014 | 08:46 AM
  #56
Cux350z's Avatar
Cux350z
hatersgonnahate
wiring pin out and link to buy the tool?
Old Feb 16, 2014 | 09:51 AM
  #57
Ragusa350z's Avatar
Ragusa350z
ohhh
Old Feb 16, 2014 | 01:13 PM
  #58
Angel55's Avatar
Angel55
The horn, cruise, next song, airbag, increase sound, and repeat work 100%. I have to change the wires to get the decrease volume to work and its good to go. But i do not have the time like i use to so it will take some time.
Old Feb 16, 2014 | 03:23 PM
  #59
2004Black350z
Exhaust Whore
Angel55 wanna send me a diy and maybe get paid for it lol
Old Feb 16, 2014 | 10:11 PM
  #60
ttknf's Avatar
ttknf
I'm looking into doing this on my car, might be a couple more months until I have the time, but I'll definitely post up a DIY with wiring diagrams when I'm done.
