Shift knob issue
Old Jun 28, 2013 | 07:13 PM
tmanstuart2's Avatar
tmanstuart2
Default Shift **** issue
I just got a round shift **** today and installed it, the only issue is the shift boot wont stay up around the bold i installed at the base of the shift **** so you can still see the shift shaft arm is there anyway to make it to where the top of the boot stays up close to the bottom of the shift ****?
Old Jun 28, 2013 | 08:06 PM
Dan Garcia's Avatar
Dan Garcia
Default you need a collar / finisher
z toys carries this item
http://www.zeetoyz.com/350zengine.htm
Old Jun 28, 2013 | 10:31 PM
winchman's Avatar
winchman
How do you use the 3-in-1 golf/key chain in the golf mode?
Old Jun 29, 2013 | 08:03 AM
SQuaLZ's Avatar
SQuaLZ
What shift **** did you install? post pics
Old Jun 29, 2013 | 09:53 AM
04.350z's Avatar
04.350z
Remove the boot and put zip ties around the lever
Old Jun 30, 2013 | 12:09 AM
TheWoo's Avatar
TheWoo
You can also stack washers (if you can find some with an inner hole big enough; I used rubber washers I bought at the plumbing section of Home Depot) or wrap tape around the upper part of the shift lever so the shift boot ring doesn't slide down all the way.
Old Jun 30, 2013 | 07:59 AM
l2iceman's Avatar
l2iceman
I just cut a small piece of cardboard and wrapped it around the shaft underneath the boot, zip tied it, and when I put the shifter trim back on, it held up the boot from falling. I then used a rubber shank from Home Depot as a finisher. Although I did try polishing the shank since it is originally a very dull rubber
Old Jun 30, 2013 | 01:33 PM
samsniss350z's Avatar
samsniss350z
To really pack it out I got some of the material that looks like insulating material and added it to the material that was already there, doubling it up and then used a zip tie. the extra material packs out the boot and the tie holds it in position. Simples.
Old Jun 30, 2013 | 01:38 PM
DarkCreep's Avatar
DarkCreep
Old Jul 9, 2013 | 06:44 PM
tmanstuart2
thank y'all! i will try a few of these options or i might just leave it how it is, i installed a datsun wood shift ****
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
