Interior Door Panel Foam Help
Old Aug 2, 2013 | 02:57 PM
Lucky736's Avatar
Lucky736
Default Interior Door Panel Foam Help
Last time I replaced the window motor I noticed the foam had come "unglued" from the interior door panel. Wondering what kind of adhesive is used so that when I go back in to reset the pinch protection on the window motor I can take care of this as well.
Thanks in advance!
Lucky736's Avatar
Lucky736
BTW this is on a 2003. I know later years had additional sound deadening that was not present in the 03.
Old Aug 2, 2013 | 05:30 PM
dcains's Avatar
dcains
You can find 3M spray adhesive at body shop supply stores, upholstery shops, fabric stores, etc.
Old Aug 2, 2013 | 05:46 PM
dcains's Avatar
dcains
At Staples:
http://www.staples.com/3M-Clear-Spra...product_715735
Old Aug 2, 2013 | 05:57 PM
Lucky736's Avatar
Lucky736
See I was curious b/c it almost looks like dried wood glue. Looks like they used a bead around the edge and that was it. Dries a dark yellow, what was on there from the factory anyway.
Old Aug 2, 2013 | 05:59 PM
dcains's Avatar
dcains
Wood glue wouldn't stick to the non-porous plastic of the door panel.
Old Aug 3, 2013 | 01:31 AM
WeightLimit's Avatar
WeightLimit
3m spray
Spray both the foam and the panel where the foam is placed. Place it on the panel for a second then pull it off. Wait for the glue to become tacky then replace it on the panel.
3vilbunny
Jul 18, 2017 05:10 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
