Sylvania headlight kit
Old Aug 18, 2013 | 04:25 PM
lilchief's Avatar
lilchief
Default Sylvania headlight kit
I just finished restoring my headlights about 2 hours ago using this kit and I'm guessing I did something wrong.... It looks worse then it did. I need help fixing it what should I do? Also how can I fix these hairline scratches on the front bumper? Please help!!
Old Aug 18, 2013 | 04:28 PM
lilchief's Avatar
lilchief
More pics
Old Aug 18, 2013 | 04:29 PM
lilchief's Avatar
lilchief
More
Old Aug 18, 2013 | 04:30 PM
lilchief's Avatar
lilchief
Last one
Old Aug 18, 2013 | 05:17 PM
dcains's Avatar
dcains
How did you NOT mask off the paint? You're going to have to repaint the fenders and bumper!
Old Aug 18, 2013 | 05:23 PM
lilchief's Avatar
lilchief
I did mask it off used the type that came with the kit.
Old Aug 18, 2013 | 06:16 PM
Touge Z's Avatar
Touge Z
those hairline cracks aren't from you restoring the headlights right?
Old Aug 18, 2013 | 06:29 PM
lilchief's Avatar
lilchief
I don't think so but I'm not sure.... Are those scratches ill be able to rib off with clay bar or wax?
Old Aug 18, 2013 | 07:09 PM
lilchief's Avatar
lilchief
Can I get another sylvania restoration kit and do it again to try and fix it since I did a bad job the first time?
Old Aug 18, 2013 | 10:35 PM
dcains's Avatar
dcains
It looks like you've taken paint off the bpdywork - or is it just the lighting?
Not sure what you did to the lights. I've got the Mother's polishing kit, which I've used a few times on my head and tail lights, even though they weren't fogged at all. That polish didn't leave even the tiniest scratches, just a glassy-smooth surface, like a clay bar on paint. Maybe try that kit instead?
If that doesn't work, try wet-sanding with some 2500 grit wet-dry paper, but be gentle, use lots of water, and use Scotch blue painter's tape to protect the paint. Then polish again with the Mother's kit, and finish with a layer of good wax.
Old Aug 19, 2013 | 01:54 AM
mcubed45's Avatar
mcubed45
did you follow the instructions?
Old Aug 19, 2013 | 01:57 AM
Touge Z's Avatar
Touge Z
turtle wax kit is good too.
Old Aug 19, 2013 | 01:34 PM
SR71's Avatar
SR71
Lead Super Moderator
Ya dun goofed.
Old Aug 19, 2013 | 05:26 PM
lilchief's Avatar
lilchief
I did follow the instructions so I'm not sure what happened..... I'm gonna try and do it again hopefully it will fix it.
Old Aug 19, 2013 | 05:43 PM
BranZ's Avatar
BranZ
What exactly did the instructions that you followed say?
Did you polish at all?
Old Aug 19, 2013 | 08:52 PM
Marrocco350z's Avatar
Marrocco350z
Get some mothers mag and aluminum polish and dab some on a rag and hand polish those the rest of the way to clear.
Old Aug 22, 2013 | 04:41 AM
lilchief's Avatar
lilchief
Do u really think that's goona work marrocco350z?
Old Aug 22, 2013 | 05:23 AM
KornerCarver's Avatar
KornerCarver
Just about any auto detailing shop will polish headlights. I would suggest taking your car to a pro and let them polish the headlights. I suspect they will get them looking like new.
Old Aug 22, 2013 | 05:58 AM
radiocrash's Avatar
radiocrash
^This or try again with a new kit. I really don't think you caused the paint damage under your headlight. Looks like it was there... and no they're small cracks so they can't be fixed by claybar. For that, you'd have to repaint. Hope this helps!
Old Aug 22, 2013 | 04:50 PM
lilchief's Avatar
lilchief
Should I just try to Polish my headlights and see if it works? If so what Polish to use? May and aluminum is for metal surfaces right?
