Setting UP HomeLink 350z 2005
Hi everyone
I bought a new garage Door Opener by a company called
SOMMER
Direct Drive 3/4 HP Synoris 550 compact
I confirmed that the system uses a rolling code for the remotes. (My system have blue remotes, older systems did not have rolling code remotes and they are red color)
Setting up the HomeLink in 4 easy steps.
( ATTENTION: Remember this will clear all the codes in your 3 buttons. So if you have other buttons programmed you need to reprogram them after you finish with this)
Step 1:
Push all 3 buttons and hold till the light goes out. ( it could take up to 2 Mins)
Step 2:
Push each button until the light becomes sold
Step 3
Push the learn button on Control housing receiver ( you have 10 Seconds to start step 4. you might need someone to help you with this step)
Step 4
Push the button you want program for 2 seconds then release, repeat up to 3 times. ( That should activate your garage door )
if that does not work, do that again. If that still does not work call HomeLink
Here is the website http://www.homelink.com/
Good Luck
SOMMER
Step 1:
Step 2:
Step 3
Step 4
Good Luck
bcoffee20
Nov 19, 2015 06:39 PM
