Fender rolling options...
I need to roll my fenders, rear wheels are rubbing slightly.
I live in Boise, Idaho and I am having a tough time finding any shops who do it.
I decided to rent the eastwood tool from Ebay, while searching DIYs on YouTube, I came accross other methods such as telephone directory, pipe and so on.
I do not wish to damage my paint and,
I am looking for your experience with these methods and thereby select the best path possible.
Thanks in advance
Thanks in advance
Be careful with the heat. Just feel it with your hand a bit. Key is patience. I used heat gun and baseball bat. I went very patiently from end to end several times. Is has been about 2 years now without any sort of problem. Paint is still solid. Whatever method you use, the key is patience and the right level of heat
good heat. almost to where you cant touch but not discoloring / burning the paint. got a little impatient with last two fenders and had a couple spider cracks and little chip off the last one. so as others mentioned. take your time and be patient. good to get a buddy to heat a 1/3 section of the arch ahead of you to help the time.
Thanks for your responses guys, I will be renting the tool shortly and I will try to post pics.
The rubbing so far is minimal and i can hear it happen when I take the corners like a gentleman
