HID Hot Spot?
Old Oct 17, 2013 | 03:45 PM
xecksx58's Avatar
xecksx58
Default HID Hot Spot?
I was going to ask about the hot spot in my bright lights on my 03 headlights, but when I went to go take pictures I realized it was both low and high beams.
What causes this, and how do I fix it? Clean the lenses? The housing lens is as clean as I can get it, but I haven't opened the lights and looked at the actual lenses.
It's a yellow garage door, that's why the lights look so yellow.
Brights
Low beam
Old Oct 17, 2013 | 04:42 PM
Jennifer 2's Avatar
Jennifer 2
Xecks, that center spot is a good thing. The 03 to 05 HID lights are high-intensity discharge low beams (with a fixed cut off), but only Halogen high beams. The high beams bulbs focus a broad swath of light above the low beam cut off (low beams stay on with high beams) and also send two pinpoints of light down the middle of the road. This adds some concentration of brightness at the farthest reach of the light pattern. In 2003 this was pretty much state of the art, however by 2006 BI-Zeon HIDs became the new standard with improved tech (movable cut-off) and made the early style obsolete. If you get a chance to buy a set of 06 to 08 lights from a wreck or ones that supposably fell of the back of a truck, etc go for it, it’s a big improvement.
Old Oct 17, 2013 | 04:53 PM
xecksx58's Avatar
xecksx58
Thanks Jennifer. I knew about the HID/Halogen combo on the 03-05 lights. Doesn't the cutoff look pretty bad to you though (on the low beams)? These are lights that I just installed to replace my stock lights (these are OEM lights still, just a different set).
My old lights didn't seem to have this issue.
The hot spot on the brights is pretty bad when driving. It was lighting up one very specific part of the road alot until I adjusted them (they were way too low, about 24.5" from 8' back. I put them up to 26"). Now I can see great, and very far down the road, but there is a hot spot on the trees far down the road and it really annoys me haha.
Old Oct 17, 2013 | 05:14 PM
Jennifer 2's Avatar
Jennifer 2
Yes, now I see the low beam part on your original post, my reading comprehension sucks. Maybe there are cheap aftermarket bulbs in the lights, they are known to have poor focal match, or maybe c focus instead of r focus HID bulbs are jammed in the lights. Either of these conditions will cause a very gleary low beam with poor distribution of light.
Old Oct 17, 2013 | 05:26 PM
xecksx58's Avatar
xecksx58
Nope, I swapped the same bulbs that were in my old lights into the new ones lol
Pleask
Dec 21, 2021 03:17 PM
ablaine
Nov 29, 2016 10:13 AM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
SharX59
Sep 30, 2015 10:54 AM
