Interior Passanger Door Grip Repair
Old Nov 13, 2013 | 09:57 AM
Mikeybfromnd's Avatar
Mikeybfromnd
Default Interior Passanger Door Grip Repair
I have an 03 base and the passenger side door grip handle (not the handle to open the door) was glued on apparently and came right off once the first passenger I had in the car grabbed it. Is there a common fix for this or would I be better off just replacing the entire passenger side interior door panel? I would imagine that an "oh-****" handle in a car like this gets ripped off quite frequently so I'm sure there's others with the same issue..
Old Nov 13, 2013 | 10:02 AM
Johnny 5's Avatar
Johnny 5
That handle is held on to the door frame by two 10mm bolts. It doesn't bolt to the door panel itself. Is the handle broken?
Old Nov 13, 2013 | 11:36 AM
Mikeybfromnd
yeah I guess it is broken then, I'm assuming that the top of the handle should have a place for the bolt to go and a part that goes into the panel but it has nothing there it was just sitting flush on the door. I'll have to inspect the door frame on the inside to see if just replacing the handle will work.
Passenger*
Old Nov 14, 2013 | 09:50 AM
Johnny 5's Avatar
Johnny 5
Im going to assume you probably just need a new handle and the two bolts. Not a huge deal.
Old Nov 14, 2013 | 10:26 AM
Neeko94's Avatar
Neeko94
It's $30 for the plastic handle and $30 for the metal fascia
Obadabot
Jun 18, 2023 11:31 PM
3vilbunny
Jul 18, 2017 05:10 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
