help on installing nardi horn button
Old Aug 11, 2015 | 11:59 PM
hatchboi's Avatar
hatchboi
Default help on installing nardi horn button
i have the nardi deep corn steering wheel, works bell rapfix II, and nardi horn button. while finishing the last part of finishing the installation which is the nardi horn button, it doesnt seem to fit into the center of the works bell. the horn button is a little too big and i actually tried to use a vice grip to squeeze the back part of the horn button to make it smaller so that i can force it into the works bell but it didnt work. i see a lot of people have the same setup installed in theirs Z and would appreciate any help on how they got the horn button to fit. thanks
Old Aug 12, 2015 | 12:45 AM
nizmo_0385's Avatar
nizmo_0385
My nardi horn didnt fit my nrg hub either. What i did was order a tiny thin spacer which allow the horn to fit snugly.
Old Aug 15, 2015 | 01:00 PM
ocdz's Avatar
ocdz
My personal horn button didn't fit my WB hub either. Just take a box cutter or sharp knife and trim down the tabs on the sides until you can force it in. You want a tight fit so it doesn't move around or fall out so just shave a little at a time until you can get it in.
Also make sure your button is working before you install it, you don't want to have to pull it all apart again.
Old Aug 16, 2015 | 11:27 AM
nizmo_0385's Avatar
nizmo_0385
Nardi horn is metal where personal is plastic.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
