Fuel Gauge and DTE read empty. HELP!
Old Jan 29, 2016 | 04:40 PM
Twenty4's Avatar
Twenty4
Default Fuel Gauge and DTE read empty. HELP!
Im having an issue that i cannot resolve. My fuel gauge reads empty always, as well as the DTE in the center pod. I have replaced the sending units, A/C amplifier AND the gauge cluster, all with zero effect. Extensive searching has shown a couple of other with this issue yet no threads show a resolution. Has anyone had this issue and fixed it? Im hoping i don't have to tear the entire dash apart and chase wiring. Input is welcome!
Old Jan 30, 2016 | 01:58 AM
karlt's Avatar
karlt
The only other possibility seems to be the wiring, either between the sending units and the A/C amp, or between the A/C amp and the gauge cluster. If the latter were the case, you would also see problems with your tachometer and coolant temperature gauge, so I suspect the wiring or connections to the senders.
Z1Motorsports
Misc.
Feb 5, 2016 08:57 AM
rottingcat
Jan 29, 2016 02:26 PM
craig12895
Interior
Jan 27, 2016 04:18 PM
