350 Roadster trunk doesn't pop open
Old Feb 13, 2017 | 06:17 PM
JnBZ's Avatar
JnBZ
Default 350 Roadster trunk doesn't pop open
Shouldn't the trunk lid pop open? Is that a function of the struts or the springs by the latch? Any quick fixes?
Old Feb 15, 2017 | 12:33 PM
Heel Til I Die's Avatar
Heel Til I Die
It should pop up a little bit so that you can manually open it, but it shouldn't open completely when you hit the trunk release button.
If it's not popping up enough to manually open it, check the springs by the latch or the latch itself to make sure it's properly aligned.
Old Mar 15, 2017 | 08:50 PM
samsniss350z's Avatar
samsniss350z
Add a couple of pennies in the rubber spring carriers on each side of the trunk. this should be enough to lift the trunk beyond the latch.
Old Mar 16, 2017 | 01:15 AM
JnBZ's Avatar
JnBZ
Thanks, Sam. My roadster is an '04, it doesn't have springs on the sides of the trunk. It has struts on the top corners of the trunk opening near the convertible top. Do those strut cylinders have springs in them?
There are two springs under rubber covers on the lid on each side of the U shaped post that engages with the latch mechanism inside the trunk. I did add two pennies to each of those springs. The change (pardon the pun) was barely noticeable.
Old Mar 16, 2017 | 05:48 AM
Heel Til I Die
The struts in the top corners operate using gas pressure and the geometry of them is designed to help open the trunk once you begin to lift it up and keep it up. They may help a little bit to get the trunk to pop up, but I think the springs by the latch are your main culprit. It seems to be a pretty common problem.
The nice thing is that the pop-up springs and the trunk struts aren't terribly expensive, so you can replace both without breaking the bank.
Old Mar 17, 2017 | 11:09 AM
JnBZ's Avatar
JnBZ
Thanks, Heel. When my trunk pops, I can barely get the tips of my fingers onto the edge of the lid to lift it. It's only 1/4" at best. How far does yours pop open?
Old Mar 20, 2017 | 06:38 AM
Heel Til I Die
I don't quite remember how high it originally popped up, but I put an aftermarket spoiler on it so it barely moves now with the added weight.
I just deal with it and I only usually keep my car cover in the trunk since real estate is limited back there.
Old Mar 20, 2017 | 09:06 AM
JnBZ's Avatar
JnBZ
Ok, thanks.
Old Mar 20, 2017 | 01:30 PM
rancor's Avatar
rancor
JnBZ I would get new springs and then add coins if you still need to. Adding more than 2 coins can damage(dent) the sheet metal and make the problem worse.
Old Mar 20, 2017 | 02:09 PM
JnBZ's Avatar
JnBZ
Thanks, rancor. The local dealer wants $110 for the springs. I can get suspension springs for my Alfa for about as much. I'm gonna pass and just deal with it.
