2003 OEM HID headlight replacement ?
on
Does anyone have any experience with replacing the headlight housings with OEM ones on a 2003 touring model? I may just buy aftermarket ones but I'd like to see what I could find for the OEM headlights. Mainly wondering the best place to buy these and how much they are going to run. Stock ones are fine just pretty fogged over . I had them "restored" at a local place and it lasted maybe a month before they looked like crap again.
350Z/370Z Tech Moderator
As an alternative, consider the best grade replacement headlights from Depo.
Careful if they're not the Depo brand, there are a lot of cheap copies out there that get less than stellar reviews (although there are a fair number of people satisfied with them.... I just err on the side of "safe decision".)
Vendor - Former Vendor
If you can buy OEM, they're not exactly cheap but waaaayyyy cheaper than buying the '06+ Bi-Xenons. Check courtesyparts.com for OEM.
Depo or OEM '07> Bi-xenon's:
http://www.ebay.com/itm/DEPO-BI-XENO...5SA-Le&vxp=mtr
Be sure to search for, and read carefully, the other threads about installing these, so you fully understand the wiring involved and the additional parts which may be needed.
