Headlight issue
Old May 25, 2017 | 04:49 AM
ECLIPSEGST25's Avatar
ECLIPSEGST25
Default Headlight issue
I have a 05 with OEM headlights. I swapped out the HIDs but the drivers side low beam won't turn on. I put that same headlight with the new setup on the passenger side and it works fine. my drivers side high beam turn on just fine just not the low beam. so I know its not the HID. what else can it be?
Old May 25, 2017 | 05:52 AM
travlee's Avatar
travlee
Master
swap ballast from side to side, take the known working passenger side and put on the drivers side....see if it is that
Old May 25, 2017 | 05:54 AM
Heel Til I Die's Avatar
Heel Til I Die
If you swapped the d/s D2R bulb to the p/s and it lit up but it doesn't light up on the d/s, then it's likely the d/s ballast, connection at the harness, etc. Something is not right on the d/s.
The high beam is halogen and doesn't use the HID ballast that the low beam uses.
Old May 25, 2017 | 06:06 AM
ECLIPSEGST25
I swapped the bulb and the ballast. and both sets work on the passenger side but neither work on the drivers side.
Old May 25, 2017 | 07:41 AM
Heel Til I Die
Try inspecting the d/s harness for loose connections or try cleaning them if there are signs of corrosion with some contact cleaner like deoxit.
If that doesn't work, 1) check the voltage for the d/s headlamp input signal, 2) check the headlamp circuit for continuity, or 3) headlamp ground.
Refer to pages LT-29 and 30 of the FSM.
Old May 25, 2017 | 01:08 PM
ECLIPSEGST25
So i tested it and the drivers side isnt getting any power that the thick red wire which im assuming is for the low beam. But the passenger side thick red wire has 12v
Old May 28, 2017 | 03:42 AM
Heel Til I Die
Try checking the 15A fuse located at No. 86 in the IPDM/ER. For some reason you're not getting a signal from terminal 30 that triggers the d/s HID to illuminate.
Here's a wiring schematic.
