Applying Nissan trunk emblem
Old Jun 21, 2017 | 10:13 AM
Eddie Jackson's Avatar
Eddie Jackson
Default Applying Nissan trunk emblem
I have a 2007 350Z roadster. I purchased a new trunk Nissan emblem. I would like to know the best way to apply it to my car. What to do prior to the application and exactly where it goes on the car (dimensions). Thanks
Old Jun 21, 2017 | 10:32 AM
jhc's Avatar
jhc
General & Tech Moderator
IIRC, the emblem has two pins on the back which insert into 2 small holes in the trunk. As far as what adhesive, I've always had great results with 3M weatherstripping and trim adhesive.
gl!
Old Jun 21, 2017 | 01:29 PM
toogood131's Avatar
toogood131
gl!
I think (not 100% sure) convertables do not have the emblem with the two pins.
Old Jun 22, 2017 | 10:57 AM
Heel Til I Die's Avatar
Heel Til I Die
I can confirm - the roadster center rear trunk emblem sits flush and lack the two pins that the coupes have. Or, at least that was the case on my '05. I doubt Nissan changed it, though.
+1 on 3m plastic emblem and trim adhesive.
As far as "prior application," I'm assuming you're referring to the OEM emblem that you're removing
I got a lot of the adhesive off with a heat gun and some paint-friendly solvents. I then polished to get any leftover lines off.
KingBaby
NISMO 350Z
1087
Sep 13, 2018 03:42 PM
Hollywood_145
Suspension
Feb 11, 2017 07:56 PM
scmtkings4
Nov 6, 2016 07:43 PM
kubech
Oct 16, 2016 12:39 PM
