Window Adjustment
Old Oct 25, 2017 | 05:06 AM
matholland618's Avatar
matholland618
Default Window Adjustment
Hey guys! I'm going to have my door panel off again to put in my Alpine components and I figured I would ask to see how I am supposed to adjust the window. The driver side back of the window is down further than the front causing some wind noise. How do I go about adjusting the height of the window? I've tried searching around, but I haven't found any good info on it...The ones I have found, the pictures are no longer working.
Old Oct 25, 2017 | 06:02 AM
Atreyu'z 350's Avatar
Atreyu'z 350
First, make sure the glass is fully seated on both ends within the window regulator assembly. Then, you'll be able to make the following adjustments. I believe it's on page/section GW-54 of the FSM...
http://www.nicoclub.com/service-manu.../coupe/2005/gw
